Dimstyle - VLisp
Dimstyle - VLisp
Dimstyle - VLisp
How in VLisp, I can attribuate the value of all the variable instead of using SETVAR ?
Is there a (vla-put.......
For example, is somebody can give me the VLisp writting to set the variable DIMEXE ?
Why? But I guess that's beside the point. Look at the object model map, Document object. You will find a method there. -- R. Robert Bell "Marcel Goulet" wrote in message news:15986544.1095341887590.JavaMail.jive@jiveforum2.autodesk.com... Hi, How in VLisp, I can attribuate the value of all the variable instead of using SETVAR ? Is there a (vla-put....... For example, is somebody can give me the VLisp writting to set the variable DIMEXE ? Thanks Thanks
