Dimension Text Width Factor
john.uhden
Mentor Mentor
Message 1 of 8
john.uhden
I don't see any property for this in 2002.  Might it have been added in newer releases?  It appears to be totally dependent on the text style definition.
John F. Uhden
Replies (7)
Message 2 of 8
cadffm
The text width depends on the text style, as long as there is no internal MText formatting.
Sebastian
Message 3 of 8
cadffm
Its normal for MText, not specially for Dimension (M)text.
Sebastian
Message 4 of 8
john.uhden
I hadn't thought of dimension text being treated the same as mtext.  The only thing I ever override is to add a suffix or a second line for a brief note, as in:
|<-----<>\X(25' min.)----->|
But the 2002 Multiline Text Editor for dimension text doesn't seem to have an option for changing the width factor of selected characters.
John F. Uhden
Message 5 of 8
cadffm
Not treaded like MText, it is a MText (and lines and arrow-insert together in a anonym *Dnnn dimension Block and you see the the insert of them.
Sebastian
Message 6 of 8
john.uhden
You lost me.  I have no idea what an anonym or Dnnn is, except that perhaps the former has no name and the latter has a bad stutter.
John F. Uhden
Message 7 of 8
cadffm
SORRY, you know about my english (and Acad) knowledge.
Anonym named objects (layer, blocks...)
Thats system objects there names start with an asterisk (*)
These objects are normally not listed for users.
Dimensions are displayed inserts of such a Block,
there names are *D1234 *D7352 and so on.
My nnn stand for "Number".
Check DXFcode 2 of a dimension!
(entget (car (entsel)))
For Mtext (inside the Block of DXFcode 2) direct
(entget (car (nentsel)))
Sebastian
Message 8 of 8
john.uhden
AHA!
There is no DXF code for width factor, but just like mtext you can add formatting codes to any or all of the text string.
Many thanks!
Actually, I haven't succeeded yet with "all" but it did work with the part I added.
John F. Uhden
