Dimension Export with tolerance
Boopathi_Sivakumar
Message 1 of 10
Boopathi_Sivakumar
Hello all,
Here is the attached LISP which is used to export all the dimensions in the drawing it is exporting as expected but is it possible to export the tolerance value with the dimension also.
please help me with this LISP
Boopathi
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
Replies (9)
Message 2 of 10
dbhunia
check...
DIMTP  & DIMTM (System Variable)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 10
Boopathi_Sivakumar
Thanks for your reply,
dimtp and dimtm is used to change the default tolerance value. if you see the attached lisp when you run the lisp it is exporting the all the dimensions in the drawing to excel but it only exports the dimensional values it is not exporting the tolerance values  so how i can add the tolerance values to the dimensions
Boopathi
Boopathi Sivakumar
www.usamcadsoft.in
Message 4 of 10
dbhunia
check THIS
Debashis Bhunia
Message 5 of 10
Moshe-A
@Boopathi_Sivakumar  hi,
check this...note that the each dimension now writes to csv 3 numbers, first the dimension Measurement, second toleranceUpperLimit, third toleranceLowerLimit
enjoy
moshe
(defun c:DimExp ( / evaluate_dimensions ; local function
		    _DIMEXPDELIMITER ss lst fname file)
 (defun evaluate_dimensions (ename / AcDbDimension Measurement tolUL tolLL toldis result)
  (setq AcDbDimension (vlax-ename->vla-object ename))
  (setq Measurement (vla-get-measurement    AcDbDimension))
  (setq tolUL  (vla-get-toleranceUpperLimit AcDbDimension))
  (setq tolLL  (vla-get-toleranceLowerLimit AcDbDimension))
  (setq toldis (vla-get-toleranceDisplay    AcDbDimension))
  (setq result (cond
                ((or (= toldis acTolNone) (= toldis acTolBasic))
                 (cons Measurement (list 0.0 0.0))
                );case
                (t ; acTolSymmetrical or acTolDeviation or acTolLimits
                 (cons Measurement (list tolUL tolLL))
                ); case
               ); cond
  ); setq
  (vlax-release-object AcDbDimension)
  result
 ); evaluate_dimensions
 ; here starts c:dimexp
 (setq _DIMEXPDELIMITER ",") ; set to "," for CSY/DEU...
 (if (setq ss (ssget "_X" (list '(0 . "DIMENSION"))))
  (progn
   (setq lst (mapcar
               '(lambda (ename)
                 (evaluate_dimensions ename)
                ); lambda
              (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
             ); mapcar
   ); setq
   (if lst
    (progn
     (setq fname (strcat (getvar "dwgprefix") "DimExp.csv"))
     (setq file (open fname "a")) ; append
     (write-line "" file)
     (princ (strcat (getvar "dwgname") _DIMEXPDELIMITER) file)
     (foreach item lst
      (foreach x item
       (princ x file)
       (princ _DIMEXPDELIMITER file)
      ); foreach
     ); foreach
     (if file (close file))
     (princ (strcat "\n" (itoa (length lst)) " dimensions written to " fname))
    ); progn
   ); if
  ); progn
 ); if
 (princ)
Message 6 of 10
Moshe-A
@Boopathi_Sivakumar
made some fine tuning corrections.
		    _DIMEXPDELIMITER ss lst fname file i)
 (defun evaluate_dimensions (ename / AcDbDimension Measurement  tolUpL tolLoL tolDiS)
  (setq AcDbDimension (vlax-ename->vla-object ename)) ; allocating memory
  (setq tolUpL (vla-get-toleranceUpperLimit AcDbDimension))
  (setq tolLoL (vla-get-toleranceLowerLimit AcDbDimension))
  (setq tolDiS (vla-get-toleranceDisplay    AcDbDimension))
  (vlax-release-object AcDbDimension); dispose memory
  (cons
    Measurement
     (cond
      ((or (= tolDiS acTolNone) (= tolDiS acTolBasic))
       (list 0.0 0.0)
      );case
       (list tolUpL tolLoL)
      ); case
     ); cond
  ); cons
 (setq _DIMEXPDELIMITER ",") ; const
 (if (and
       (setq lst (mapcar
                  '(lambda (ename)
                   ); lambda
                 ); mapcar
       ); setq
     ); and
  (progn
   (setq i 0)
   (foreach item lst
    (foreach x item
     (princ x file)
     (if (< (setq i (1+ i)) (* (length item) (length lst)))
    ); foreach
   ); foreach
  ); progn
 ); if
 (princ)
); c:DimExp
Message 7 of 10
Boopathi_Sivakumar
@Moshe-A  Thanks for your help.
The Values getting it in columns can by any mean converted to rows?
Boopathi
Boopathi Sivakumar
www.usamcadsoft.in
Message 8 of 10
Moshe-A
do you mean writing each dimension on separate line?
Message 9 of 10
Boopathi_Sivakumar
Yes That's Right
Boopathi
Boopathi Sivakumar
www.usamcadsoft.in
Message 10 of 10
dbhunia
Try with this some modifications in @Moshe-A  code (All credit goes to @Moshe-A )
		    ss lst fname file i Cont)
  (cons
    Measurement
     (cond
       (list 0.0 0.0)
      );case
      ); case
     ); cond
  ); cons
 (defun DPlace (No / Dim Val)
  (setq Dim (getvar "DIMZIN"))
  (setvar "DIMZIN" 11)
  (setq Val (if (= No (fix No)) 0 (- (strlen (rtos No 2 8)) (+ (strlen (itoa (fix No))) 1))))
  (setvar "DIMZIN" Dim)
  Val
 (if (and
       (setq lst (mapcar
                  '(lambda (ename)
                   ); lambda
                 ); mapcar
       ); setq
     ); and
  (progn
   (setq Cont (getvar "dwgname"))
   (foreach item lst
    (foreach x item
     (setq Cont (strcat Cont "," (rtos x 2 (DPLACE x))))
    ); foreach
    (write-line Cont file)
    (setq Cont " ")
   ); foreach
  ); progn
 ); if
 (princ)
Debashis Bhunia
