Different ways to do BATTMAN using visual lisp and VLA function
DGRL
Advisor Advisor
DGRL
Dear forum members,
Using ObjectDBX Wrapper from Lee Mac to open en process dwg's in the background, I'm looking for an way to do BATTMAN when processing the DWG
Does anybody knows how to do this? as commands are not allowed
Currently I don't know the VLA way of doing batman
Best regards,
If this was of any help please kudo and/or Accept as Solution
Kind Regards
DannyNL
As far as I know that's not possible while using ODBX.
Only solution I can think of is iterating though all blocks with the specified name in your drawing, store for each block the parameters like insertion point, scale, rotation and store all attribute values. Then delete the block, reinsert the block with the same properties as the original one and fill all attributes with their corresponding values based on attribute tag.
DGRL
HI @DannyNL
Thanks for the reply.
I'm thinking of an different approach to do this.
Maybe without using ODBX.
Best regards,
Kind Regards
