Visual LISP, AutoLISP and General Customization
Different Look for Unicode Linetype depending on Versions
16 REPLIES 16
Message 1 of 17
joshua_modglin
455 Views, 16 Replies
I have an interesting situation where linetypes that have been working in 5 versions no longer work in 2025.
The linetype definition is below using Arial font for the Standard text style.
In any version before 2025, the symbol comes out beautifully. In 2025, it no longer shows any symbol.
*RWATERX,Regular Water _____~_____~_____~_____~_____~_____~_____
A,0.5,["\U+032E",STANDARD,S=.1875,R=0,x=0.064,y=0.018755],-0.1875,["\U+032F",STANDARD,S=.1875,R=0,x=-0.064,y=0.051],-0.0
2024 Sample2024 Sample
2025 Sample2025 Sample
Josh Modglin
470.219.4534
Tags (2)
16 REPLIES 16
Message 2 of 17
paullimapa
in reply to: joshua_modglin
What is your Text Style named STANDARD using as the font file?
AutoCAD uses txt.shx and I've also tried simplex.shx & times.shx on your linetype definition in both the latest 2024.1.6 & 2025.1.1 and both look the same with question marks:
Paul Li
IT Specialist
@The Office
Message 3 of 17
The font being used is the TTF Arial font.
Josh Modglin
470.219.4534
Message 4 of 17
paullimapa
When I select Arial for my Standard Text Style in both 2024 and 2025 I don’t see any characters show up not even the question marks. Perhaps you can share a sample dwg?
Paul Li
IT Specialist
@The Office
Message 5 of 17
Please see attached sample drawing.
Josh Modglin
470.219.4534
Message 6 of 17
paullimapa
When I open your dwg in both 2024 & 2025 I get the same prompt to select a replacement for this missing shape file so I just cancel out since I don't have anything I can use to replace it:
And once again I don't see anything not even question marks as characters in between the lines with your linetypes:
Paul Li
IT Specialist
@The Office
Message 7 of 17
Sea-Haven
Worked in Bricscad V24 &V 25 but got error message.
Substituting font "FRAHV.TTF" by default font.
Message 8 of 17
i haven't had any problem with displaying these linetypes in 25 with arial font.
have you tried to change the font for the standard textstyle and see what will the lines show up?
@paullimapa
mecsline.shx has nothing to do with above lines. it is used in others, like haybale for instance.
Message 9 of 17
paullimapa
in reply to: komondormrex
Odd that I don’t see any characters in between the lines in both the latest 2024 & 2025 using ttfs. Then when I try shx all I see are the ? characters. Even when I try to enter that Unicode character within the mtext editor I get nothing too.
Paul Li
IT Specialist
@The Office
Message 10 of 17
Interesting. You are the first 2025 user that has that result. We are running AutoCAD 2025.1.1 on Win11 Pro 24H2
Is your setup any different?
We did try multiple fonts prior to posting. No font change brings back the water symbol. With Arial Unicode font, other symbols came back such as the symbol in the lighting linetype.
Some things that speak to the issue:
  • Consistent results for our users which seems to make sense based on computer setups being similar
  • Varied results from the field (thanks to all who have tested)
  • As Paul mentioned, the issue is not just linetypes. Unicode symbols cannot be typed into MText either. They just disappear.
Thanks for all the help to troubleshoot. Without knowing the cause, I am concerned about changing the character in the linetype or changing the font since it worked on multiple computers for years. Without identifying the cause what will stop it from happening again?
Josh Modglin
470.219.4534
Message 11 of 17
paullimapa
Perhaps sign into your Autodesk account and submit a troubleshooting ticket
Paul Li
IT Specialist
@The Office
Message 12 of 17
paullimapa
here's a new development...when I disable DirectX12 in 2025.1.1 (GFXDX12 = 0 & restart AutoCAD) then I see the character...so that's the problem
Paul Li
IT Specialist
@The Office
Message 13 of 17
Sea-Haven
What about using tilde in line type "~" its a single character so no need for unicode. Top left on my keyboard.
A,40,-5.08,["~",STANDARD,S=1.8,R=180.0,X=0.0,Y=.9],-3
Message 14 of 17
joshua_modglin
in reply to: paullimapa
Well that is interesting. Not a fix but definitely the culprit. I was able to test and duplicate results.
Thanks.
Josh Modglin
470.219.4534
Message 15 of 17
joshua_modglin
in reply to: Sea-Haven
Although that may be a workaround (the symbology is different but close) for this linetype, we have many linetypes that use Unicode symbols. I only posted one example. It also doesn't explain what changed.
Josh Modglin
470.219.4534
Message 16 of 17
paullimapa
So your previous versions may have been running DirectX 11 & not the latest DirectX 12 which is why the latest 2025 install shows this difference.  Keep in mind there are only certain graphics cards that Autodesk has certified and if you have one of those then it's worth reporting to them about this problem.
Paul Li
IT Specialist
@The Office
Message 17 of 17
yes, it is rather different, but your problem is somewhat weird to me. never had such one.
AutoCAD Inside the Factory
