DieselExpression
DieselExpression
MBAlonso
DieselExpression
MBAlonso
Hello!
I have the following expression:
$(+,$(rtos,$(substr,$(getvar,dwgname),9,2),1,0),1)
I would like to add a 0 if the value is less than 9 to get 01, 02, 03... 10, 11, etc.
Any idea?
Thanks!
Sea-Haven
Must it be diesel ? This is a lisp example checks if sheet is <10.
(if (< dwgnum 10.0)
      (setq newstr2 (strcat dwgname "-D0"  (rtos sheetnum 2 0)))
      (setq newstr2 (strcat dwgname "-D"  (rtos sheetnum 2 0)))
MBAlonso
Thanks.
Mmm... but I do not have the entire code using LSP.
Kent1Cooper
The Diesel Functions Reference does not appear to include anything equivalent to the AutoLisp (strcat) function for joining [concatenating] text strings together.  Without something like that, it's hard to picture how you could get what you're after, but I don't use Diesel enough to feel sure about it.
Kent Cooper, AIA
Paul_Gander
Try this as a direct replacement for your expression:
$(if,$(<,$(substr,$(getvar,dwgname),9,2),9),0)$(+,$(substr,$(getvar,dwgname),9,2),1)
It should work although it's not really clear what you are trying to achieve. Is your expression part of a menu macro or a field? I'm guessing that you are wanting to do a SAVEAS with the incremented number in the drawing name.
MBAlonso
Thanks everyone!
@Paul_Gander: I was trying (and I got it because of your help) to write the current page in a text (the number is part of the DWG name) and, in a second text, the following page.
For example: Page 01. Next Page 02.
