Diesel Expression on variable length drawing file names.
dpalmerVQ54W
Message 1 of 12
dpalmerVQ54W
Is there a way of using Diesel Expressions to adapt to variable length filenames?
My company mainly uses 5 digit project codes, eg 12345. Quite often we have to add a -00X to the project code eg 12345-001.
So in the following filename:
12345-ABC-ZZ-03-M2-Y-00001-IPMS3-S3-P01
becomes
12345-001-ABC-ZZ-03-M2-Y-00001-IPMS3-S3-P01
When the longer project name is used I lose part of it in my title block, see below:
to
12345-001.jpgI
The PC Project Code in the second image should display 12345-001
and I'm losing 4 characters in the Drawing No.
The Diesel expression for the PC Project No. is currently $(substr,$(getvar,dwgname),1,5) this obviously works ok for the 5-character project number but not the 9-character.
The Diesel expression for the Drawing No. is currently $(substr,$(getvar,dwgname),1,15) this obviously works ok for the 5-character project number but not the 9-character.
I don't want to have create sperate templates for different length project numbers as we have enough already.
Thanks in anticipation.
David P
AutoCAD 2021
Replies (11)
Message 2 of 12
Paul_Gander
Try this for the Project Number:
$(substr,$(getvar,dwgname),1,$(+,5,$(*,4,$(>,$(strlen,$(getvar,dwgname)),43))))
Change the 5 to 15 for the Drawing Number field.
The macro simply adds 4 to the length of the substring if the drawing name has more than 43 characters (including the .dwg suffix)
Message 3 of 12
paullimapa
Are you not able to use lisp code because you’re running LT?
Can you share your title block drawing that has the diesel?
Paul Li
IT Specialist
@The Office
Message 4 of 12
dpalmerVQ54W
Thanks @Paul_Gander
That worked for the PC Project No field. I tried in the Drawing No. field but I ended up losing other characters.
Referring back to my screenshots the grey highlight is the part the diesel code is covering.
I'm trying to minimise the amount of editing required to the drawing number.  This is BSI (British Standards Insitute) numbering. Some elements change, some are fixed. I've just had a thought if it would be better to break the drawing number up using, say a single row table, and use diesel code in each cell?🤔
@paullimapa I'm using full ACAD 2021 I don't want to have to run a lisp routine to create borders. We have sub-contractors who use our borders, some of whom use LT or other non-ACAD products.
Thanks for your help to-date.
David P
AutoCAD 2021
Message 5 of 12
Paul_Gander
What characters were missing? Are the filenames not always the same length and format before you insert the additional numerical code?
If the length and format varies then it may not be possible to determine if the extra characters have been added.
Message 6 of 12
Kent1Cooper
.... I don't want to have to run a lisp routine to create borders. We have sub-contractors who use our borders, some of whom use LT or other non-ACAD products.
AutoLisp would be able to look at the first three characters after the first hyphen, and determine whether they are all numerical, in which case it would know the overall string is the longer variety.  I don't see an equivalent are-they-numbers capability in Diesel for LT users.  Even if there is one, can the "other non-ACAD products" use Diesel code?
Kent Cooper, AIA
Message 7 of 12
dpalmerVQ54W
12345-001(WITH NEW CODE).jpg@Paul_Gander as you can see in the screenshot I've lost the -ABC-ZZ-03 in the Drawing No.
@Kent1Cooper with regards to your question about non-AutoCAD products using Diesel it does appear to work. I know a couple of our sub-contractors use BricsCAD and the data that comes back from them is fine in terms of using Diesel code.
David P
AutoCAD 2021
Message 8 of 12
paullimapa
Like @Kent1Cooper the challenge occurs if the file names are not fixed in length, for example, for the shorter project #, will all possible drawing file name lengths always be 39 characters:
And then for the longer project #, will all possible drawing file name lengths always be 43=39+4 characters:
If the answer is no, then there's no way to test when the filename would have the additional project # characters because Diesel does not offer an option to test alpha vs numeric characters.
 So in this case, there's no way to differentiate if there's a "-001" vs "-ABC"
But if you know for certain that the shorter project #s will always have drawing file name lengths of 39 characters, then Diesel can be used to test that and then return project code as just 12345.  But if longer, then return project code as 12345-001
Paul Li
IT Specialist
@The Office
Message 9 of 12
dpalmerVQ54W
I hadn't realised how complex this was going to get! The filename could get longer as one of the options for a filename could be 12345-001-ABC-ZZ-03-M2-Y-00001-IPMS2_TA-S3-P01.
David P
AutoCAD 2021
Message 10 of 12
paullimapa
Then you’re stuck with having to create sperate templates for different length project numbers.
Now if you implement  project name variable to store your project number  then Diesel can grab that as your project number in the title block. But implementing that variable will require each drawing when created to run a command to setvar “projectname”. So this is not full proof.
Paul Li
IT Specialist
@The Office
Message 11 of 12
pgander
Did you change the 5 to 15 for the drawing number,  as I suggested in message 2?
$(substr,$(getvar,dwgname),1,$(+,15,$(*,4,$(>,$(strlen,$(getvar,dwgname)),43))))
Message 12 of 12
dpalmerVQ54W
Thanks @pgander that seems to have worked. I missed your earlier comment.
David P
AutoCAD 2021
