diesel expression:Counting down from the end
Vuxvix
Message 1 of 16
Vuxvix
Hi!
My file name form: AAAA-BBBB-CCCC
Inside: AAAA and CCC was fixed
BBBB is the name of each drawing.
I'm using the Diesel function to insert a name (BBBB) into a drawing canvas.
$(SUBSTR,$(GETVAR,DWGNAME),No.1,$(-,$(STRLEN,$(GETVAR,DWGNAME)),No.2))
Inside:
No.1: The start letter of the string
No.2: the starting letter of the omitted part.
Problem: Because BBBB item is not fixed number of letters. Is there any way to remove the CCCC part. By way of counting down from the end?
Thank you very much
Replies (15)
Message 2 of 16
pbejse
Try this
$(substr,$(getvar,dwgname),6,$(-,$(strlen,$(getvar,dwgname)),14))
Message 3 of 16
Vuxvix
Hi!
Sorry, I don't see anything different with my Diesel Line!?
Message 4 of 16
pbejse
@Vuxvix wrote:
Hi!
That means i definitely misunderstood the question :D, that is also how i would do it with Diesel
What's supposed to be the result for this anyway?
  • AAAA-BBBB-CCCC.dwg
  • AAAA-BANANA-CCCC.dwg
Message 5 of 16
Kent1Cooper
@Vuxvix wrote:
.... Because BBBB item is not fixed number of letters. Is there any way to remove the CCCC part. By way of counting down from the end?....
AutoLisp can do that easily, with the (vl-string-position) function, which can find the position of the last hyphen in a string by looking for it from the end.  The Diesel functions reference does not list any function that appears capable of doing the same.  Is AutoLisp code an option for you?
Kent Cooper, AIA
Message 6 of 16
Vuxvix
Hi!
this is my example for Drawing's name: R-03-06_4FPlan (Drafting).
I just need: "4FPlan" to display as title in Drawing frame.
Currently I only know about Diesel Function and some default fields in Autocad. I think there is no restriction in using Lisp.
Also, I don't know if using Lisp will display correctly on other PC. Because I have had cases where Fields show #### results on other PC.
Thanks!
Message 7 of 16
Vuxvix
Hi funny guy!
The result I want is: BBBB.
It will display as the title in the drawing Frame. So I don't need its prefix and suffix (nor dwg format)
Message 8 of 16
Kent1Cooper
@Vuxvix wrote:
My file name form: AAAA-BBBB-CCCC ....
The result I want is: BBBB. ....
-- and --
Those are very different.  Are you looking for the part between two hyphens, or the part between an underscore character and a space?  Are there any other configurations?
Kent Cooper, AIA
Message 9 of 16
Vuxvix
Follow the way of counting the number of letters as the original way.
I have given the form in an A-B-C Form.
Part [-C]: will depend on the type of drawing. With [space], [-] or [a specified character after], can lisp  do it!? Thanks
Message 10 of 16
Kent1Cooper
I doubt it can do it reliably, given the examples.  Both  AAAA-BBBB-CCCC  and  R-03-06_4FPlan (Drafting)  contain two hyphens; in one of them you want what's between the hyphens, but in the other you want something else.  You're going to need some criteria that are more consistent.
Kent Cooper, AIA
Message 11 of 16
Vuxvix
I hope this makes it easier to understand
Message 12 of 16
pbejse
@Vuxvix wrote:
Hi!
I still dont see why what you had on your diesel expression wouldnt work if the number of characters for the PREFIX and SUFFIX is constant.
Unless you have different cases like the one you just posted as R-03-06_4FPlan (Drafting).dwg then you may need to use a system variable for the for both No.1 and No.2 assign via lisp
$(substr,$(getvar,dwgname),$(getvar,useri1),$(-,$(getvar,useri2),$(getvar,useri1)))
(defun RunAtStartpp ()
  (cond
    ((zerop (getvar 'DwgTitled)))
    ((And
       (setq fname (getvar 'dwgname))
       (setq p (vl-string-position 32 fname nil t ))) ; space
       (setvar 'USeri1 9)(setvar 'USeri2 (1+ p))
     ((setq p (vl-string-position 45 fname nil t )) ; Hyphen/dash
       (setvar 'USeri1 6)(setvar 'USeri2 (1+ p))
[ One just need to add more conditions ]
OR just this if you're going to with the lisp route
$(getvar,users1)
  (cond
    ((And
       (setq p (vl-string-position 32 fname nil t))
     )					; space
     (setvar 'Users1 (substr (getvar 'dwgname) 9 (- (1+ p) 9)))
    ((setq p (vl-string-position 45 fname nil t)) ; Hyphen/dash
     (setvar 'Users1 (substr (getvar 'dwgname) 6 (- (1+ p) 6)))
Thats the bit that concerns me. Why would it behave that way on other PC?
Is it because its Autocad LT?
Message 13 of 16
Kent1Cooper
So Message 1 should have started with:
My file name form: AAAA_BBBB CCCC
Is that correct?
Kent Cooper, AIA
Message 14 of 16
Kent1Cooper
If that's the real situation, and there is only one underscore character and one space, then there's no need to find the space by counting back from the end.  That would only have been necessary in the original format containing two of the same character [hyphens] that you want to break it around.
This will get what you want out of a string like the above:
(setq str "AAAA_BBBB CCCC")
(substr str (+ (vl-string-position 95 str) 2) (- (strlen str) (vl-string-position 32 str) 1))
returns "BBBB".  If the string is just "A_B C", it returns just the "B".  Etc.
Kent Cooper, AIA
Message 15 of 16
Vuxvix
Sorry for not being able to reply for a while.
I tried the following function in the attachment:
I double checked my Field in the post. actually the omitted part has been counted down from the end. I noticed {.dwg} is numbered :12-9 respectively. The coincidence of the length of the string of letters in the file name confused me. Apologies for this silliness.
@pbejse:
-I tried your Diesel code. The results are returned as shown in the attached file. It doesn't seem to work for me.
-I don't know how to use your lisp code. can you show me how to use it. Sorry about that
-As you said, every other computer in my office uses Autocad Lt. People here rarely use hotkeys, let alone lisp.
@Kent1Cooper:
-I also don't know how to use your lisp code. Does that create a Field in the Field list to choose from!?
Message 16 of 16
Kent1Cooper
@Vuxvix wrote:
@pbejse:
@Kent1Cooper:
Since AutoCAD LT does not support AutoLisp at all, my code will be of no use to your other users.
But where you can use it, my code does nothing other than get the substring out of the longer string.  That can be used in whatever way is needed, by other code.
Kent Cooper, AIA
