Dialog box not displaying
neam
neam
Hi to all.
I use a Lisp, which with a slight change in it, I use the dialog box to enter the parameters that should be changed in the block attribiute specifications.
But when I transfer it to another system, the dialog box is not shown.
Both systems have the same specifications (windows 7 & Autocad 2019).
komondormrex
he there,
you have to check if dcl file is in the 'Working Support File Search Path' or state it as full filename in your lisp same to every system environment .
neam
Thank dear komondormrex
it was a very subtle point.
