Detect the interface language in a lisp routine
lucdoucet_msdl
Advisor Advisor
Message 1 of 11
lucdoucet_msdl
I would like to know if it is possible to return the current Autocad interface language to allow me to set a variable.
My specific case is that that the default table cell style name of "Data" is "Données" when the french language interface is active in the current Autocad session. I would like the following table setting function not return an automation error:
(vla-SetCellStyle tbl row cell "Données") vs (vla-SetCellStyle tbl row cell "Data")
Thanks for any help.
Accepted solutions (3)
Replies (10)
Message 2 of 11
Moshe-A
check DWGCODEPAGE or SYSCODEPAGE system variables
Message 3 of 11
DannyNL
Try this as well
(vl-registry-read (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key)) "Language")
Message 4 of 11
cadffm
@lucdoucet_msdl
What is the Value of cellstyle now? In my german version the cellstyle is internatinal "_DATA"
(vla-getcellstyle tblobj 0 2) = "_DATA" and not german like "DATEN"
_DATA _HEADER and _TITLE (and "")
Sebastian
Message 5 of 11
roland.r71
Tried "_Data" ?
If you use the _ prefix you can use the international (english) commands & values.
like "_Y" = Yes, in any acad language, "_last" for the last object created etc.
No need to set the right language.
Besides: i wouldn't know of any such variable. (doesn't mean it's not existent )
There are 2 system vars, people refer to in my search, but both are invalid.
LOCALE & DCTMAIN - Both return NLD (as thats where i am) but my interface language for ACAD (still) is English, not Dutch.
Anyway, as for commands and standard "answers" (Yes, No, Previous, Last, etc, etc.) this isn't needed. Just add a _ to the English/standard text and it will tell acad to use/accept the international versions.
Message 6 of 11
roland.r71
@DannyNL wrote:
Try this as well
"English"
Correct! Smiley Happy
Message 7 of 11
cadffm
(ver)
Sebastian
Message 8 of 11
lucdoucet_msdl
Thanks, this solution would work best for identifying the current interface language when deciding how to respond to users that aren't bilingual. In my case, the best solution would be the simplest, that is to prefix the cell style with an underscore as suggested by roland.r71
Luc
Message 9 of 11
lucdoucet_msdl
Thanks to CADffm and roland.r71, it works!
This is the simplest and most straightforward solution.
Message 10 of 11
lucdoucet_msdl
Nope, both the french and english Autocad installs return the same result : "ANSI_1252"
Message 11 of 11
lucdoucet_msdl
This also works but requires us to parse the string result and look for "fr" or "en"
results: "Visual Lisp 2017 (fr)" and "Visual Lisp 2017 (en)"
