Detail Lisp
Detail Lisp
paul9ZMBV
Detail Lisp
paul9ZMBV
I would like a Lisp to enable me to draw a circle and and then it copies everything in the circle and then asks for a scale to enlarge it.
I have found a lisp online (below) and it kind of work, but seems to do other things after it has scaled it but i cant work out what the other features are, perhaps someone can read the lisp below and work it out please.
; TIP782.LSP Enlarge an Area for a Detail (c)1992, Victor V. Jensen
; - Modified for Release 11.
; [DETAILS.LSP]
; Global variables: s#v, olderr.
(prompt "\nLoading functions")
; details error function
(defun deterr (S / A L)
(if (/= S "Function cancelled") (princ (strcat "\nError: " S)))
(command nil) (command ".UNDO" "B")
(foreach A s#v
(if (= (car A) "CLAYER")
(command "LAYER" "S" (cadr A) "") (setvar (car A) (cadr A))
(setq *error* olderr s#v nil olderr nil)
(princ)
(princ ".")
; sscross function
(defun sscross (/ S1 S2)
(setq S1 (ssget "C" P2 P3) S2 (ssget "W" P2 P3))
(if (/= (sslength S1) (sslength S2))
(progn (command ".SELECT" S1 "R" S2 "") (ssget "p"))
) ; if
(princ ".")
; explode function
(defun explode (EN / A C E I L R S E1 E2 E3 S1 S2)
(setq S2 (ssadd))
(while (setq EN (entnext EN))
(setq E (entget EN) ET (cdr (assoc 0 E)) E1 (cdr (assoc 41 E))
E2 (cdr (assoc 42 E)) E3 (cdr (assoc 43 E))
(if (= HL 1) (redraw EN 3))
(cond
((= ET "INSERT")
(if (= (abs E1) (abs E2) (abs E3))
(if (or (< E1 0) (< E2 0) (< E3 0))
(progn
(setq A (entlast) C (cdr (assoc 10 E)) I (cdr (assoc 2 E))
L (cdr (assoc 50 E)) R (car C) S (cadr C)
(entdel EN) (setq S1 (ssadd))
(command ".INSERT" (strcat "*" I) C (abs E1) 0)
(while (setq A (entnext A)) (setq S1 (ssadd A S1)))
(if (< E1 0) (command ".MIRROR" S1 "" C (list R (+ 10 S)) "Y"))
(if (< E2 0) (command ".MIRROR" S1 "" C (list (+ 10 R) S) "Y"))
(if (/= L 0) (command ".ROTATE" S1 "" C (* (/ 180 pi) L)))
(command ".EXPLODE" EN)
(ssadd EN S2)
)) ; if
((member ET '("POLYLINE" "DIMENSION")) (command ".EXPLODE" EN))
((ssadd EN S2))
) ; cond
) ; while
(setq S1 (ssget "C" P2 P3))
(command ".ERASE" S2 "R" S1 "")
(princ ".")
; id function
(defun id (E / EN ET)
(setq EN (cdr (assoc -1 E)) ET (cdr (assoc 0 E)))
(if (= ET "ARC")
(list EN ET (cdr (assoc 50 E)) (cdr (assoc 51 E))) (list EN ET)
) ; if
(princ ".")
; trim output function
(defun op (EN ET)
(if
(not
(and (<= (- (car P2) 1E-6) (car ET) (+ (car P3) 1E-6))
(<= (- (cadr P2) 1E-6) (cadr ET) (+ (cadr P3) 1E-6))
(progn (command (list EN ET)) T)
) ; if
(princ ".")
; trim function
(defun trim (/ I L EN ET EA SA S1 TM E C R D90 D270)
(while OK (setq OK nil I 0 S1 (sscross) L (if S1 (sslength S1) 0))
(if (> L 0) (command ".TRIM" C2 ""))
(repeat L (setq EN (ssname S1 I) E (entget EN) ET (cdr (assoc 0 E)) I (1+ I))
(if (not (member (id E) TM))
(progn (setq TM (cons (id E) TM))
(cond
((= ET "LINE") (op EN (cdr (assoc 10 E))) (op EN (cdr (assoc 11 E))))
((= ET "CIRCLE") (setq C (cdr (assoc 10 E)) R (cdr (assoc 40 E)) OK T)
(cond
((op EN (list (+ R (car C)) (+ 0.0 (cadr C)))))
((op EN (list (+ 0.0 (car C)) (+ R (cadr C)))))
((op EN (list (+ (- R) (car C)) (+ 0.0 (cadr C)))))
((op EN (list (+ 0.0 (car C)) (+ (- R) (cadr C)))))
)) ; cond
((= ET "ARC")
(setq C (cdr (assoc 10 E)) R (cdr (assoc 40 E)) SA (cdr (assoc 50 E))
EA (cdr (assoc 51 E)) OK T D90 (/ pi 2) D270 (* pi 1.5)
(if (> SA EA) (setq EA (+ EA (* pi 2))))
(cond
((op EN (polar C SA R)))
((op EN (polar C EA R)))
((or (<= SA 0.0 EA) (<= SA (* pi 2) EA)) (op EN (polar C 0.0 R)))
((or (<= SA D90 EA) (<= SA 0.0 EA)) (op EN (polar C D270 R)))
((or (<= SA pi EA) (<= SA (* pi 3) EA)) (op EN (polar C pi R)))
((or (<= SA D270 EA) (<= SA (* pi 3.5) EA)) (op EN (polar C D270 R)))
)) ; cond
)) ; cond
)) ; if
(if (> L 0) (command ""))
) ; while
(princ ".")
; main program
(defun C:DETAILS (/ A E I L R DT EN ET HL OK TM C1 C2 S1 P0 P1 P2 P3 P4 P5)
(setq DT (* (getvar "DIMSCALE") (getvar "DIMTXT")) HL (getvar "HIGHLIGHT")
olderr *error* *error* deterr
A '("HIGHLIGHT" "BLIPMODE" "OSMODE" "CLAYER" "ORTHOMODE")
s#v (mapcar '(lambda (L) (list L (getvar L))) A)
(setvar "CMDECHO" 0) (setvar "BLIPMODE" 0) (setvar "OSMODE" 0)
(command ".UNDO" "M" ".LAYER" "S" "0" "ON" "0" "")
(while (= OK nil)
(initget 1) (setq P1 (getpoint "\nDetail centerpoint: "))
(princ "\nEncircle detail: ") (command ".CIRCLE" P1 PAUSE)
(setq C1 (entlast) R (cdr (assoc 40 (entget C1))) L (sqrt (* (expt R 2) 2))
P2 (append (list (+ (car P1) R) (cadr P1))) A (angle P2 P1)
P2 (polar P1 (* A 1.25) L) P3 (polar P1 (* A 0.25) L)
(if (> (sslength S1) 1) (setq OK T)
(progn (setq OK nil) (princ "\nNothing selected!") (command ".ERASE" C1 ""))
) ; if
) ; while
(setvar "ORTHOMODE" 0)
(princ "\nLocate detail: ") (command ".COPY" C1 "" P1 PAUSE)
(setq P4 (getvar "LASTPOINT") C2 (entlast))
(setvar "HIGHLIGHT" 0)
(command ".COPY" S1 "" P1 P4)
(setvar "HIGHLIGHT" HL)
(setq P2 (polar P4 (* A 1.25) L) P3 (polar P4 (* A 0.25) L) EN C2)
(princ "\nProcessing data...please wait.")
(explode EN)
(trim)
(setq S1 (sscross) L (if S1 (sslength S1) 0) I 0)
(if (member ET '("LINE" "CIRCLE" "ARC")) (entdel EN))
(initget 6)
(if (setq HL (getreal "\nScale factor <1.0000>: "))
(command ".SCALE" "C" P2 P3 "" P4 HL)
(setq P3 (polar P4 (* A 1.5) (cdr (assoc 40 (entget C2))))
P4 (polar P3 (* A 1.5) (* DT 2)) P5 (polar P4 (* A 1.5) (* DT 2))
TM (strcase (strcat "DETAIL-" (getstring " DETAIL-")))
ET (strcat "SCALE: " (getstring " SCALE: "))
(initget 1) (setq P2 (getpoint P1 "\nLocate leader text: "))
(if (or (<= (angle P1 P2) (/ A 2)) (>= (angle P1 P2) (* A 1.5)))
;--------------------------------- Release 9 ----------------------------------
; (progn (setq I "L" P3 (polar P2 (- A pi) (* DT 2))
; P0 (polar P2 (- (* A 2) 0.167) (* DT 2.6)))
; (progn
; (setq I "R" P3 (polar P2 A (* DT 2)) P0 (polar P2 (+ A 0.167) (* DT 2.6)))
😉 ; if
;(if (= I "L") (command ".TEXT" P0 DT "0" TM) (command ".TEXT" I P0 DT "0" TM))
;--------------------------------- Release 11 ---------------------------------
(progn (setq I "ML" P3 (polar P2 0.0 (* DT 2)) P0 (polar P2 0.0 (* DT 2.5))))
(progn (setq I "MR" P3 (polar P2 A (* DT 2)) P0 (polar P2 A (* DT 2.5))))
) ; if
(command ".LINE" P1 P2 P3 "" ".TRIM" C1 "" P1 "" ".TEXT" I P0 DT "0" TM
".TEXT" "M" P4 (* DT 1.5) "0" (strcat "%%U" TM)
".TEXT" "M" P5 DT "0" ET
(foreach A s#v
(command ".LAYER" "S" (cadr A) "") (setvar (car A) (cadr A))
(princ)
) ; end program
(princ "loaded.")
(C:DETAILS)
Donald857HY
I have this that should do what you ask.
(defun C:DETAIL1 ( / P1 EN EL PTS SS1)
(cond
;;Set up AutoCAD system variables
((DETAIL_0)
(prompt "\nError in DETAIL_0"))
;;Operator input of detail center
;;and radius.
((DETAIL_1) ;;set up EL, P1, RD
(prompt "\nError in DETAIL_1"))
;;Operator input of detail graphic location
;;and scale for detail display.
;;Copy detail area, remove non-detail objects
;;like dimensions and text, and scale as
;;input by the operator.
((DETAIL_2) ;;set up P2, SS1, EN, ENT, SCL
(prompt "\nError in DETAIL_2"))
;;Do the trimming of the detail display.
((DETAIL_3)
(prompt "\nError in DETAIL_3"))
;;Create the text tag and draw connecting
;;line between original area and detail
;;area.
((DETAIL_4) ;;Output text tag
(prompt "\nError in DETAIL_4"))
('T (prompt "\nDetail finished okay."))
;;Reset system variables
(mapcar '(lambda (X)
(setvar (car X) (cadr X))) SYSVAR_LIST)
(prompt "\nUse TRIM to complete if needed.")
(princ)
;; Listing 2: Set up system variables
(defun DETAIL_0 ()
(setq SYSVAR_LIST (mapcar '(lambda (X)
(list X (getvar X)))
'("CMDECHO"
"OSMODE"
"ORTHOMODE"
"HIGHLIGHT"
(setvar "OSMODE" 0)
(if (zerop (getvar "TILEMODE")) ;;make sure we are mspace
(if (= (getvar "CVPORT") 1) (progn ;;we are in paper space!
(alert "You must be in Model Space for this routine to function!")
(exit) ;;hard abort!
(if (zerop (getvar "WORLDUCS"))
(command "_UCS" "_W"))
nil
;; Listing 3: Establish area to detail
(defun DETAIL_1 ()
(setq P1 (getpoint "\nDetail center: "))
(if P1 (progn
(prompt "\nShow detail area: ")
(command "_CIRCLE" P1 pause)
(setq EN (entlast)
EL (entget EN)
RD (if (= (cdr (assoc 0 EL)) "CIRCLE")
(cdr (assoc 40 (entget EN)))
nil)
(if RD (progn
(entdel EN)
(command "_POLYGON" 15 P1 "I" RD)
(setq EN (entlast)
EL (entget EN)
nil ;return nil
1 ;return error level 1.
) ;;level 1 is RD not set
2 ;;return error level 2.
) ;level 2 is P1 not set
;; Listing 4: Copy objects to new location
(defun DETAIL_2 ()
(while (setq TMP (assoc 10 EL))
(setq EL (cdr (member TMP EL))
PTS (cons (cdr TMP) PTS)
(entdel EN)
(setq SS1 (ssget "CP" PTS)
P2 (getpoint P1 "\nPut detail at: ")
CNT (if SS1 (sslength SS1) 0)
(if P2 (progn
(repeat CNT
(if (member
(cdr (assoc 0
(entget
(ssname
SS1
(setq CNT (1- CNT))))))
;'("TEXT" "DIMENSION"
; "MTEXT" "INSERT"
'("MTEXT")
(ssdel (ssname SS1 CNT) SS1)
(command "_CIRCLE" P1 RD
"_CIRCLE" P2 RD)
(setq EN (entlast)
ENT EN)
(command "_COPY" SS1 "" P1 P2)
(setq SS1 (ssadd EN))
(while (setq ENT (entnext ENT))
(ssadd ENT SS1)
(setq SCL (getreal "\nScale factor (2): "))
(if (null SCL) (setq SCL 2.0))
(if (/= SCL 1.0)
(command "_SCALE" SS1 "" P2 SCL)
nil ;;return nil result, all okay.
1 ;;return error code 1
) ;;error code, P2 not input.
;; Listing 5: Trim the objects copied
(defun DETAIL_3 ()
(setq TTT 0) ;;change counter
(while (setq ENT (ssname SS1 0))
(ssdel ENT SS1)
(if (not (equal ENT EN)) (progn
(setq EL (entget ENT)
PT (DETAIL_3A EL)
(if (and PT
(> (distance P2 PT)
(+ 0.2 (* RD SCL))))
(progn
(setq TTT (1+ TTT))
(command "_TRIM" EN ""
(list ENT PT) "")
(DETAIL_3B) ;;loop again check
nil
;; Listing 6: Find point on object for trim
(defun DETAIL_3A (EL / TY)
(setq TY (cdr (assoc 0 EL)))
(cond
((= TY "LINE")
(if (> (distance (cdr (assoc 10 EL)) P2)
(distance (cdr (assoc 11 EL)) P2))
(cdr (assoc 10 EL))
(cdr (assoc 11 EL))
((= TY "ARC")
(setq PC (cdr (assoc 10 EL))
PR (cdr (assoc 40 EL))
PA (cdr (assoc 50 EL))
PB (cdr (assoc 51 EL))
(if (> (distance (polar PC PA PR) P2)
(distance (polar PC PB PR) P2))
(polar PC PA PR)
(polar PC PB PR)
((= TY "CIRCLE")
(cond
((> (distance P2
(polar PC 0.0 PR))
(* RD SCL))
(polar PC 0.0 PR))
((> (distance P2
(polar PC PI PR))
(* RD SCL))
(polar PC PI PR))
((> (distance P2
(polar PC (* 0.5 PI) PR))
(* RD SCL))
(t (polar PC (* 1.5 PI) PR))
((= TY "LWPOLYLINE")
(setq PR nil)
(while (and (null PR)
(setq PA (assoc 10 EL)))
(setq EL (cdr (member PA EL))
PA (cdr PA)
(if (> (distance P2 PA) (* RD SCL))
(setq PR PA)))
((= TY "SPLINE")
(setq PR nil)
(setq PA (assoc 11 EL))
PA (cdr PA))
(setq PR PA)))
((= TY "POLYLINE")
(setq EL (entget
(entnext
(cdr (assoc -1 EL))))
PR nil)
"VERTEX"))
(setq PA (cdr (assoc 10 EL))
EL (entget
(entnext
(* RD SCL))
(setq PR PA)
;;add more objects here
) ;;end COND for PT assignment
;; Listing 7: Loop control options for user
(defun DETAIL_3B ()
(if (= (sslength SS1) 0)
(if (> TTT 0) (progn
(initget 0 "Yes No")
(setq TTT (getkword (strcat
"\nChanged "
(itoa TTT)
" objects, Loop again? <Yes>")))
(if (or (null TTT) (= TTT "Yes"))
(progn
ENT EN)
(ssadd ENT SS1)
(setq TTT 0)
;; Listing 8: Finishing touches
(defun DETAIL_4 ()
(command "_TEXT"
"_Justify" "_Center"
(polar P2
(* PI 1.5)
(+ (* SCL RD)
(* 2.5
(getvar "TEXTSIZE"))))
(if (zerop (cdr (assoc 40
(tblsearch
"STYLE"
(getvar "TEXTSTYLE")))))
(command "") ;;text height output option
(command 0 ;;finish the TEXT command sequence.
(strcat "Enlarged "
(rtos SCL 2
(Best_Prec SCL 0 4))
"x")
;; Construct line between detail circles.
(command "_LINE" (polar P1 (angle P1 P2) RD)
(polar P2 (angle P2 P1) (* RD SCL))
nil
;; Listing 9: Utility Routine from toolbox
;; Best_Prec - Given a number (NUM) and the
;; minimum and maximum precision, this function
;; returns the precision in the range that will
;; best fit the number.
(defun Best_Prec (Num Mn Mx)
(while (and (<= Mn Mx)
(/= Num (atof (rtos Num 2 Mn))))
(setq Mn (1+ Mn))
Mn
; [DETAILS.LSP]
(foreach A s#v
(princ)
(princ ".")
; sscross function
) ; if
(princ ".")
; explode function
(setq S2 (ssadd))
(cond
((= ET "INSERT")
(progn
(ssadd EN S2)
)) ; if
((ssadd EN S2))
) ; cond
) ; while
(princ ".")
; id function
(if (= ET "ARC")
) ; if
(princ ".")
(defun op (EN ET)
(if
(not
) ; if
(princ ".")
; trim function
(cond
(cond
)) ; cond
((= ET "ARC")
(cond
)) ; cond
)) ; cond
)) ; if
) ; while
(princ ".")
; main program
(while (= OK nil)
) ; if
) ; while
(explode EN)
(trim)
(initget 6)
; (progn
😉; if
) ; if
(foreach A s#v
(princ)
) ; end program
(princ "loaded.")
(C:DETAILS)
Sea-Haven
Try this just does scale objects. NO circle but some one smarter than me will add Grrdraw circle. The repeat emaulates a circle if problems selecting increase the repeat value and change the pi10 to match its 1/2 the repeat.
(defun c:sclobj ( / pt1 pt2 lst rad ss)
(setq pt1 (getpoint "\nPick centre point "))
(setq pt2 (getpoint pt1 "\nPick outside point "))
(setq lst '() pi10 ( / pi 10.0)  ang (- ( / pi 10.0)))
(setq rad (distance pt1 pt2))
(repeat 20
(setq lst (cons (polar pt1 (setq ang (+ ang pi10)) rad) lst))
(setq lst (cons (last lst) lst))
(setq ss (ssget "WP" lst ))
(if (= ss nil)
(princ "selection failed ")
(command "scale" ss "" pt1 (getreal "\nEnter scale factor "))
(princ)
