Design Review Polycloud customization
I work with Adobe pfd's that must be Redlined. I use the polycould function and would like to know how I can make the clouds more precise without distorting the edges of the polycloud.
Attached is what I mean the Red arrows show that the cloud has straight lines which I do not want, I need the bubbles to be like the Green arrows.
Regards
Kent1Cooper
Welcome to these Forums!
AutoCAD's REVCLOUD command doesn't do that, and it [at least "vanilla" AutoCAD] has no "Polycloud" command or function that I'm aware of [or that Help is aware of].  It looks like you need to be on an Adobe Forum [if there's anything like that to address a question like yours], rather than an AutoDesk Forum.  Or if you're somehow red-lining .PDF's with some AutoCAD-based software, is it some kind of overlay program with a specialty function that's not in basic AutoCAD?  If so, and it's an AutoDesk overlay, there should be a Forum for that, specifically.
Kent Cooper, AIA
