Design of a math function
mmawad
Message 1 of 9
mmawad
I need help designing a function that does the following
There is 2 objects "A & C" each represented by 2 real type variables
And we have a third object "B" but  we only have the first variable for it and need to estimate what the second variable value should be relative to the first 2 objects.
By the way that first variable that we have will always be in between the other 2 objects first variables.
The inputs are,
(setq
         A1 40
         A2 500
         B1 50
         C1 60
         C2 900
And the result is B2 value.
Replies (8)
Message 2 of 9
marko_ribar
Is B2=700 ?
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 9
marko_ribar
(defun findb2 ( a1 b1 c1 a2 c2 / da1c1 db1c1 da1b1 da2c2 db2c2 db2a2 b2 )
  (setq da1c1 (- c1 a1))
  (setq db1c1 (- c1 b1))
  (setq da1b1 (- b1 a1))
  (setq da2c2 (- c2 a2))
  (setq db2c2 (* (/ db1c1 da1c1) da2c2))
  (setq db2a2 (* (/ da1b1 da1c1) da2c2))
  (setq b2 (+ a2 db2a2))
  (if (equal (- c2 b2) db2c2 1e-8)
    (progn
      (prompt "\nB2 = ")
      (princ (rtos b2 2 50))
  (princ)
Message 4 of 9
Kent1Cooper
Given:
(setq
  A1 40
  A2 500
  B1 50
  C1 60
  C2 900
then:
(setq  B2
    A2 ; low end of range between x2 values
      (/ (float (- B1 A1)) (- C1 A1)); ratio of B1 position between A1 and C1
      (- C2 A2); overall x2 range
); setq
The (float) function is there to make at least one number be a real  number, because if all inputs are integers, the division result will also be an integer with any remainder ignored, throwing off the result.
Kent Cooper, AIA
Message 5 of 9
marko_ribar
Yes, I missed (float) function, so OP - if using my function must specify real numbers...
Message 6 of 9
Kent1Cooper
@marko_ribar wrote:
(setq db2c2 (* (/ db1c1 da1c1) da2c2)) (setq db2a2 (* (/ da1b1 da1c1) da2c2)) ....
That has the divide-integers problem.  Both of these calculations:
(/ db1c1 da1c1)
(/ da1b1 da1c1)
return zero when the inputs are as in Message 1.  So nothing gets added to the A2 value, the B2 result comes out as 500, and the prompt is not issued.
Kent Cooper, AIA
Message 7 of 9
marko_ribar
I explained in message 5 that OP needs to use real numbers if wanted to get correct result...
Message 8 of 9
Kent1Cooper
Yes -- it was posted while I was already writing Message 6.  But I have a few other comments:
I wonder about that  (if (equal ...  test, which seems unnecessary.  With real-number inputs, under what circumstances could it ever not  be equal?  And if there is such a circumstance, shouldn't there also be an 'else' expression notifying the User that something's amiss, rather than nothing at all being reported [as happened when I ran it with integer inputs]?
The precision number of 50 in the  (rtos)  function is serious overkill.  AutoCAD can only keep track of 16 significant figures, so you will never get anywhere close to 50 decimal places returned by anything:
  Command: (rtos 700 2 50)
  "700.0000000000000"
[only 13 decimal places]
A lot of your variables are used only once, so it doesn't seem necessary to save them -- just figure them at the place where they're used.  That's how my suggestion, which uses no  variables added beyond the inputs except B2, boiled down to its essence without comments and line breaks, is no more than just:
(setq B2 (+ A2 (* (/ (float (- B1 A1)) (- C1 A1)) (- C2 A2))))
And if the  (if (equal ...  test is really not needed, the db2c2 variable is also not needed.
Kent Cooper, AIA
Message 9 of 9
marko_ribar
You are right, check is not needed indeed, but according to math rules it should return T, only if assumed arithmetic operations are true... If for ex. there is another rule (B2 /= 700), but for ex. B2 = 500 + (900-500)*((50-40)/(60-40))^((50-40)/(60-40)) = 500 + 400*0.5^0.5 = 500 + 282.8427 = 782.8427, then my (if) statement wouldn't give T and therefore assumed arithmetics won't give any result... The question that we don't have answer to is answer to my first reply : Is B2=700 ?
Now as OP marked our solutions as correct, he/she assumed that B2=700 and so my (if) checking only confirms assumed logic and no matter not necessity it acts as proof that logic used is correct...
