Visual LISP, AutoLISP and General Customization
Delete files older that 'X' days in specific folder
4 REPLIES 4
jpCADconsulting
190 Views, 4 Replies
Hi folks. I had some LISP in acad.doc that would delete all files in "C:\_AutoSave" that are older than 180 days on launch of AutoCAD.
It used to work -- I think. Here is the code. It just reports 'nil' and does nothing.
Any light you can shine on this for me is greatly appreciated.
(foreach file
           (mapcar (function (lambda (x) (strcat "C:/_AutoSave/" x)))
                   (vl-directory-files "C:/_AutoSave/" "*.*" 1)
    (if (not (vl-file-systime file))
      (prompt (strcat "\n** No systime for \"" file "\" ** "))
4 REPLIES 4
pbejse
in reply to: jpCADconsulting
This line doesn't do anything except evaluate if the variable file does not evaluate to nil
There's something missing in the code you posted @jpCADconsulting
modify the code here to suit your needs
Paul Li
IT Specialist
@The Office
Moshe-A
@jpCADconsulting  hi,
here is a fix to your code
to find the difference between dates i assumed :
1 year contains 365 days in average
1  month contains 30 days in average
to calculate the exact days is another 'story' :grinning_face:
enjoy
Moshe
(defun delete_older_files (/ elapses_days ; local function
			     fname f sysTime^ fileTime^ days0 days1 file)
 ; anonymous function
 (setq elapsed_days (lambda (lst) (+ (* (car lst) 365) (* (cadr lst) 30) (cadddr lst))))
 (setq fname (vl-filename-mktemp)) ; temporay file name
 (setq f (open fname "w"))
 (setq f (close f))
 (setq sysTime^ (vl-file-systime fname))
 (setq days0 (elapsed_days sysTime^))
 (foreach file (mapcar (function (lambda (x) (strcat "C:/_AutoSave/" x)))
		      					(vl-directory-files "C:/_AutoSave/" "*.*" 1))
  (if (not (setq fileTime^ (vl-file-systime file)))
   (progn
    (setq days1 (elapsed_days fileTime^))
    (if (> (- days0 days1) 180)
     (vl-file-delete file)
   ); progn
  ); if
 ); foreach
); delete_older_files
jpCADconsulting
in reply to: pbejse
Yeah, I didn't know why I didn't see that. Totally obvious now. :winking_face:
AutoCAD Inside the Factory
