Delete everything inside circles
stephenwFKTB4
stephenwFKTB4
i have a lisp routine to trim scribe lines and add circles but i need something to select everything inside the yellow circle and delete it, then delete the circle.
i have  the code to select all my circles but am struggling with the rest
(if (setq ss (ssget "_X" '((0 . "CIRCLE") (8 . "TEXT"))))
    (progn ; then
	(repeat (setq n (sslength ss))
		(setq
          cir (ssname ss (setq n (1- n)))
	  ); progn
 i attached the whole code and the dxf i am working with
thanks
paullimapa
This thread may point you in the right direction to select objects inside a circle
Paul Li
IT Specialist
@The Office
Sea-Haven
I  think this will do what you want, select circle select inside.
Need to add delete circle, but should be there to remember the object selected. Maybe line 703.
stephenwFKTB4
Thanks guys,  while trying to get those suggestions to work i figured out i could just use a rectangle since i will only ever need to select those 5 lines.
