Visual LISP, AutoLISP and General Customization
delete double vertices
2 REPLIES 2
656 Views, 2 Replies
hi
i have got a polyline with different vertices having the same coordinates. is there a possibility to clean the pline?
thanks a lot
2 REPLIES 2
_gile
Here's a routine which removes all oversnaped vertices of lwpolylines 2D polylines or 3D polylines.
(comments in french)
;;; Clean_poly Supprime tous les sommets superposés des polylignes, optimisées, 2D et 3D
;;; TRUNC Retourne la liste tronquée à partir de la première occurrence
;;; de l'expression (liste complémentaire de celle retournée par MEMBER)
(defun trunc (expr lst)
(cond
((or (null lst)
(equal (car lst) expr)
nil
(T (cons (car lst) (trunc expr (cdr lst))))
;;; Fonction principale
(defun c:clean_poly (/ ent e_lst p_lst vtx1 vtx2)
(while (not
(setq ent (car (entsel "\nSélectionnez une polyligne: ")))
(setq e_lst (entget ent))
(cond
((= "LWPOLYLINE" (cdr (assoc 0 e_lst)))
(setq p_lst (vl-remove-if-not
'(lambda (x)
(or (= (car x) 10)
(= (car x) 40)
(= (car x) 41)
(= (car x) 42)
e_lst
e_lst (vl-remove-if
'(lambda (x)
(member x p_lst)
e_lst
(if (= 1 (cdr (assoc 70 e_lst)))
(while (equal (car p_lst) (assoc 10 (reverse p_lst)))
(setq p_lst (reverse (cdr (member (assoc 10 (reverse p_lst))
(reverse p_lst)
(while p_lst
(setq e_lst (append e_lst (trunc (assoc 10 (cdr p_lst)) p_lst))
p_lst (member (assoc 10 (cdr p_lst)) (cdr p_lst))
(entmod e_lst)
((and (= "POLYLINE" (cdr (assoc 0 e_lst)))
(zerop (logand 240 (cdr (assoc 70 e_lst))))
(setq e_lst (cons e_lst nil)
vtx1 (entnext ent)
vtx2 (entnext vtx1)
(while (= (cdr (assoc 0 (entget vtx1))) "VERTEX")
(if (= (cdr (assoc 0 (entget vtx2))) "SEQEND")
(if
(or (not
(equal (assoc 10 (entget vtx1))
(assoc 10 (last (reverse (cdr (reverse e_lst)))))
(zerop (logand 1 (cdr (assoc 70 (last e_lst)))))
(setq e_lst (cons (entget vtx1) e_lst))
(if
(not
(equal (assoc 10 (entget vtx1)) (assoc 10 (entget vtx2)) 1e-9)
(setq vtx1 vtx2
vtx2 (entnext vtx1)
(setq e_lst (reverse (cons (entget vtx1) e_lst)))
(entdel ent)
(mapcar 'entmake e_lst)
(T (princ "\nEntité non valide."))
(princ)
Gilles Chanteau
GileCAD
GitHub
hi
this works wonderful to me.
thank you very much.
christoph
Forma Design Contest
