Delete Blok inside attribute
bahaatawfiq
bahaatawfiq
hi every I have arch Plan and thy made hatch inside furniture ,grid  and Tags I found lisp Which Delete hatch  from all drawings but I need update it to delete hatch only from selected item because I need to keep wall hatch
(defun c:Test (/ doc)
 (vlax-for bks (vla-get-blocks (setq
                     doc (vla-get-ActiveDocument (vlax-get-acad-object))
   (if (and (eq :vlax-false (vla-get-islayout bks))
            (eq :vlax-false (vla-get-isXref bks))
     (vlax-for obj bks
       (if (and (wcmatch (vla-get-objectname obj)
                         "AcDbHatch"
                (vlax-write-enabled-p obj)
         (vla-delete obj)
 (vla-regen doc AcAllViewports)
 (princ)
)(vl-load-com)
 can any one help with this
Sea-Haven
Try this
(defun c:Test (/ blks ent bks blks obj)
(setq blks (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))))
(while (setq ent (entsel "\nPick a block Enter to exit "))
  (setq bname (cdr (assoc 2 (entget (car ent)))))
  (vlax-for bks blks
			(eq (vla-get-name bks) bname)
     (vlax-for obj bks
                         "AcDbHatch"
         (vla-delete obj)
 (princ)
)(vl-load-com)
bahaatawfiq
Unfortunately not worked, I get error "Pick a block Enter to exit ; error: bad argument type: VLA-OBJECT nil" as sample i need to delete the solid hatch from the grid and window and door tags .that sample project i have project with huge number of same issue
john.uhden
@bahaatawfiq
Those Aussies tend to skip over things.
Change
to
(while (setq ent (car (entsel "\nPick a block, Enter to exit: ")))
John F. Uhden
ronjonp
@Sea-Haven
No need to iterate all the blocks in the drawing if you're picking them ?
(defun c:test (/ blks bname ent)
  (setq blks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
  (while (and (setq ent (car (entsel "\nPick a block Enter to exit ")))
	      (setq bname (cdr (assoc 2 (entget ent))))
	      (tblobjname "BLOCK" bname)
    (vlax-for obj (vla-item blks bname)
      (if (wcmatch (vla-get-objectname obj) "AcDbHatch")
	(vl-catch-all-apply 'vla-delete (list obj))
  (princ)
(vl-load-com)
