DELETE BLOCK NAMED "APPROVED FOR CONSTRUCTION" FROM ALL DRAWINGS
ferrisb
ferrisb
Happy Friday All.
Does anyone know of a way to do this?
_gile
Hi
The following code erases all references of "APPROVED FOR CONSTRUCTION" block and purges it  from the drawing it is run in.
If you want to batch process multiple drawings, you'd use it in a batch script application as ScriptPro 2.
((lambda (/ b s i)
   (if (setq b (tblobjname "BLOCK" "APPROVED FOR CONSTRUCTION"))
     (progn
       (if (setq s (ssget "_X" '((0 . "INSERT") (2 . "APPROVED FOR CONSTRUCTION"))))
	 (repeat (setq i (sslength s))
	   (entdel (ssname s (setq i (1- i))))
       (command "_.purge" "_blocks" "APPROVED FOR CONSTRUCTION" "_no")
Gilles Chanteau
GileCAD
GitHub
ferrisb
Do you know where I can get a download for script pro, or something like it?
_gile
Try this one:
https://github.com/ADN-DevTech/ScriptPro-installer
Gilles Chanteau
GileCAD
GitHub
