Delete all user defined properties
Uwe_Lindner
Uwe_Lindner
Dear forum, we are looking for a way (e.g. using a Lisp routine) to delete all user-defined properties in an open AutoCAD file.
Is there a way to do this?
We haven't found a standard function for this in AutoCAD.
We therefore hope that this is possible with an LSP routine.
Thank you very much!
Moshe-A
@Uwe_Lindner  hi,
AutoCAD file can contain hundreds (or much beyond) of custom user defined properties such as:
blocks
layers
linetypes
dimension styles
text styles
and more...
instead of clearing all that you can start a new drawing base on a template.
Moshe
DGCSCAD
If you mean Drawing Properties -> Custom...
Solution from here: https://www.cadtutor.net/forum/topic/77226-delete-all-custom-properties-help/#google_vignette
(defun C:DCF (/ App Doc DwgProps)
  ;;; Delete all Custom Fields
  (setq App (vlax-get-acad-object)
        Doc (vla-get-ActiveDocument App)
        DwgProps (vla-get-SummaryInfo Doc))
  (repeat
    (setq n (vla-NumCustomInfo DwgProps))
    (vla-RemoveCustomByIndex DwgProps (setq n (1- n)))
  (princ)
AutoCad 2018 (full)
Win 11 Pro
