Delete all frozen layers
Message 1 of 12
Hi, I am pretty new to lisp and I was wondering if there was a way to go through all layers, check if it is frozen, and if it is delete it. I already have a function that freezes the layers I want deleted specifically. I was looking into using
(vlax-for Lay (vla-get-Layers ActDoc)
        (if
                (= (vla-get-Freeze Lay) ':vlax-true)
to see if it is frozen and "laydel" to delete the layer, but I am unsure how to proceed from here. Any help would be welcome.
Thanks!
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Q: why don't you just WBLOCK out the drawing to create a new file once all of these layers are frozen? same end result, just quicker.
Message 3 of 12
Hi Pendean,
Does WBLOCKing the drawing remove the frozen layers? I tried it myself and it didn't work. I need to remove the frozen layers. I did also try to WBLOCK objects and manually selected the layer, which worked, but I am unsure on how to recreate that in a lisp.
Thanks for telling me about this though!
Message 4 of 12
dbhunia
Try like this
(setq lay_Col (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))
(vlax-for Lay lay_Col
	(if (= (vla-get-Freeze Lay) :vlax-true)
		(if (= (vla-get-Lock Lay) :vlax-false)
			(vl-cmdf "_.-laydel" "_N" (vla-get-Name Lay) "" "_Y")
For more see This
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 5 of 12
ronjonp
I've been using this one for years:
(defun c:frzlaydel (/ doc err fzl msg n n2)
  ;; RJP » 2019-07-19
  (setq err 0)
  (setq n 0)
  (setq n2 0)
  ;; Get frozen layers
  (vlax-for lay	(vla-get-layers (setq doc (vla-get-activedocument (vlax-get-acad-object))))
    (and (not (wcmatch (vla-get-name lay) "*|*"))
	 (or (eq (vla-get-freeze lay) :vlax-true) (eq (vla-get-layeron lay) :vlax-false))
	 (setq fzl (cons lay fzl))
	 (vla-put-lock lay :vlax-false)
  (if (setq fzl (mapcar 'vla-get-name fzl))
    (progn (vlax-for b1	(vla-get-blocks doc)
	     (vlax-for b2 b1
	       (if (vl-position (vla-get-layer b2) fzl)
		 (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-delete (list b2)))
		   (setq err (1+ err))
		   (setq n (1+ n))
		 (setq n2 (1+ n2))
	   (setq msg (strcat (strcat (itoa err) " errors deleting objects...\n")
			     (strcat (itoa n) " objects were deleted, ")
			     (strcat (itoa n2) " objects were ignored.")
	   (if (zerop (getvar 'cmdactive))
	     (alert msg)
	     (princ msg)
    (princ (strcat "\nNo eligible layers found."))
  (princ)
Message 6 of 12
dbhunia Your code worked great! I was able to delete all the frozen layers. rperez I am not sure if I did something incorrectly, but it only deleted some of the objects, ignored most of them, and did not delete the layers. Since it worked for you, I am pretty sure it is my fault, but it does not matter anymore. Thanks everyone for helping me with this!
I have another question, which might be dumb. Is there a way to remove x-ref layers in the same way?
Message 7 of 12
ronjonp
Might just need to add a purge at the end of the code to remove the layers. You cannot remove xref layers.
Tried to modify the code above but missed the magical 30 minute mark ;/ .. so here it is again:
  ;; RJP » 2019-07-19
  (setq err 0)
  (setq n 0)
  (setq n2 0)
	     (vlax-for b2 b1
		   (setq err (1+ err))
		   (setq n (1+ n))
		 (setq n2 (1+ n2))
	     (alert msg)
	     (princ msg)
	   (repeat 2 (vla-purgeall doc))
  (princ)
Message 8 of 12
pendean
Community Legend
Community Legend
Late response: Frozen layers are always removed in WBLOCK unless you have content that still use those layers.
Message 9 of 12
josue777torsan
How can I invoque the command after save it as .lsp?
Architect, CAD Manager in Mexico City
Message 10 of 12
Kent1Cooper
Always the part right after (defun C:
(defun C:ThisIsTheCommandName (....
[the C can be capitalized or not, and the command name is not case-sensitive]
Kent Cooper, AIA
Message 11 of 12
josue777torsan
Yes, but I do not see the defun c: in the code  I quoted
Thanks Kent
Message 12 of 12
aadish_rahman
thank you very much
