delete all freeze and off layer
michaelZCXYL
Message 1 of 10
michaelZCXYL
I am wondering if there is way to delete all freeze and off layer, many thanks. 🙂
Replies (9)
Message 2 of 10
chriscowgill7373
Delete all frozen and off layers?  You could use the LAYDEL command (just create a (command) with the proper prompts answered), but typically deleting layers that have objects on them can cause corruption.   So you might want to delete all those entities first.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 3 of 10
ronjonp
@michaelZCXYL
I use this almost daily:
(defun c:frzlaydel (/ d er fl n n2)
  ;; RJP » 2020-08-05
  (mapcar 'set '(er n n2) '(0 0 0))
  ;; Get frozen and off layers
  (vlax-for lay	(vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object))))
    (and (not (wcmatch (strcase (vla-get-name lay)) "*|*,0,DEFPOINTS"))
	 (or (= -1 (vlax-get lay 'freeze)) (= 0 (vlax-get lay 'layeron)))
	 (setq fl (cons (vla-get-name lay) fl))
	 (vlax-put lay 'lock 0)
  (if fl
    (progn (vlax-for b1	(vla-get-blocks d)
	     ;; If it's not an xref
	     (if (= 0 (vlax-get b1 'isxref))
	       (vlax-for b2 b1
		 (if (vl-position (vla-get-layer b2) fl)
		   (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-delete (list b2)))
		     (setq er (1+ er))
		     (setq n (1+ n))
		   (setq n2 (1+ n2))
	   (repeat 3 (vla-purgeall d))
	   (princ (strcat (itoa er)
			  " errors deleting objects...\n"
			  (itoa n)
			  " objects were deleted, "
			  (itoa n2)
			  " objects were ignored."
    (princ (strcat "\nNo eligible layers found."))
  (princ)
Message 4 of 10
ВeekeeCZ
Could be handy. But... a bit too powerful for my taste. I would probably add the option to save objects inside blocks. These objects are difficult to acknowledge.
Message 5 of 10
ronjonp
@ВeekeeCZ Yeah it's a bit brute force but I use this for my bases from clients to slim them up as much as possible 🙂
Message 6 of 10
pendean
Community Legend
Community Legend
@ronjonp I like it (quick test here on a couple of files, I could use this occasionally to send files to others): safety off folks, user beware!!!!
Message 7 of 10
ronjonp
@pendean Thanks!
It's been very helpful for me. I couple it with code to change certain layer colors and force everything to bylayer then super purge and close. 😎
On average after I 'clean' a base it's reduced in file size over 50%-90%.
Message 8 of 10
michaelZCXYL
@ronjonp Great Job ! 🙂
Thank you very much all of you!
Message 9 of 10
rkalachov6AB4Y
Observer
Observer
It worked for me, thank you
Message 10 of 10
ronjonp
You're welcome! : )
