Block reference is the block that is inserted into a space, model paper.
Block definition is the block in the block collection. With either one, I
would assume you could use (entdel ename) or (vla-Delete blkobj). If you
get an error, then the block is inserted into the drawing, this would only
occur when trying to delete the block definition from the block collection.
Tim
"A blind man lets nothing block his vision."
wrote in message news:5435460@discussion.autodesk.com...
Hi...
How I can delete block reference of database without using purge?
Thank you...
