defun syntax error
defun syntax error
Jonathan_Bell82GXG
defun syntax error
Jonathan_Bell82GXG
Using ACAD LT 2024 -
when I enter a defun statement to the command line (or in a .lsp file), it throws a syntax error:
Command: (setq test "test")
"test"
Command: (defun c:OFFSETAUTO ( / offset circSel circDef x y) )
; error: syntax error
Command: (defun OFFSETAUTO (/ offset circSel circDef x y) )
Command: (defun)
Command: (defun fun)
Command: (defun fun (/))
Kent1Cooper
You haven't told the command or function to do anything.  And what does the 'test' variable have to do with anything?
Kent Cooper, AIA
Jonathan_Bell82GXG
APPLOAD'ing this in results in the same syntax error
; need to be able to specify area to work in for roof edge offset
; retrieving list of entities to offset
  ; exterior roof
    ; roof distinction either by different layers for int/ext or by assuming ext roof is outer edge of dwg
  ; interior roof
  ; mech/HVAC
; offset breakdown
  ; pline (rec is same as pline) "LWPOLYLINE"
    ; closed pline
    ; pline against edge (3 sides)
    ; pline against corner (2 sides)
  ; circle
    ; just copying circle won't work, must draw new
; MAIN PROGRAM OUTLINE
; retrieve list of all entities to offset
; join all lines to polyline
; "offset" each
  ; copy, displacement (doesn't require joining, would require multiple copies to be made + trimming) OR ent functions (more complicated, potentially more robust across versions)
; trim
; optional end message display
; ((-1 . <Entity name: 23aff7d2b90>)
; (0 . "CIRCLE")
; (330 . <Entity name: 23a94a08f70>)
; (5 . "43CE71")
; (100 . "AcDbEntity")
; (67 . 0)
; (410 . "Model")
; (8 . "PV Vents Skylights Roof Drains")
; (100 . "AcDbCircle")
; (10 6.68465e+08 -6.12824e+08 0.0)
; (40 . 71.3673) !! -> RADIUS (default units - inches)
; (210 0.0 0.0 1.0))
;;; PAST PROTOTYPES
; PROTO. 2: 4' offset (layer "PV VENTS SKYLIGHTS ROOF DRAINS", color BYLAYER) around all circles on layer "PV Roof Obstructions"
; MOD - error handling/checking throughout
(defun c:OFFSETAUTO (/ offset circSel circDef x y)
    ; offset vars
    (setq offset 4) ; 4 inch offset
    (setq osLayer "PV VENTS SKYLIGHTS ROOF DRAINS") ; layer of offset
    (setq osColor "BYLAYER") ; offset color
    (if (not (ssget "_I"))
        ; if no currently active selection set:
        (princ "\nhere")
        (progn
            (setq pt1 (getpoint "\nSpecify first corner: "))
            (setq pt2 (getcorner pt1 "\nSpecify opposite corner: "))
            (setq ss (ssget "_C"
                            pt1
                            pt2
                            '((0 . "CIRCLE") (8 . "PV Roof Obstructions")) ; select all circles on PV Roof Obstructions layer
        ; else there is an active selection set:
        (setq ss (ssget "_I"
                        '((0 . "CIRCLE") (8 . "PV Roof Obstructions")) ; select all circles on PV Roof Obstr layer from implied ss
    ; DEBUGGING - print length of selection set
    ; (princ
    ;     (strcat "\nSSLENGTH: "
    ;             (itoa (sslength ss))
    ; loop through entities in selection set
    (setq ssnum 0)
    (repeat (sslength ss)
        ; DEBUGGING - Print ename of each entity in ss
        ; (princ (strcat "\n"
        ;                (vl-princ-to-string (ssname ss ssnum))
        ; Get entity name and assoc list for each entity
        (setq ename (ssname ss ssnum))
        (setq circDef (entget ename))
        ; getting x, y coord, radius of each circle
        ; could make helper for radius too
        (getCoord "x" circDef)
        (getCoord "y" circDef)
        ;; HERE - RADIUS HELPER
        (setq radPair (assoc '40 circDef))
        (setq rad (cdr radPair))
        ; modified radius, radius dotted pair
        (setq radNew (+ rad offset))
        (setq radPairNew (cons 40 radNew))
        ; current layer, new layer
        (setq cLayerPair (assoc '8 circDef))
        (setq osLayerPair (cons 8 osLayer))
        ; current color dotted pair, new color dotted pair
        (setq cColorPair (assoc '62 circDef))
        (setq osColorPair (cons 62 osColor))
        ; MOD - helper func using mapcar to make changes to assoc list given new dotted pair
        ; new circle assoc list with changed radius, layer
        (setq newCircDef (subst radPairNew radPair circDef))
        (setq newCircDef (subst osLayerPair cLayerPair newCircDef))
        ; change to specified color
        (command "COLOR" osColor)
        ; create offsets
        (setq osEntDef (entmake newCircDef))
        ; increment ssnum
        (setq ssnum (1+ ssnum))
    ; exit quietly
    (princ)
;;; HELPER FUNCTIONS ;;;
; GETCOORD - returns x or y coordinate of entity
; ADD ERROR HANDLING
(defun getCoord (coordName entList /)
  ; VARLIST
  ;; INPUTS
  ;;; coordName - name of coordinate to get, x or y (STR)
  ;;; entList - entity definition to extract coordinate from (ASSOC LIST)
  ;; LOCAL VARS - NONE
  (if (equal (strcase coordName T) "x")
      ; if x coord:
      (float
          (nth 1
                (assoc '10 entList)
      ; else y coord:
      (float
          (nth 2
                (assoc '10 entList)
Kent1Cooper
I don't understand why in Message 1 you seem to be assuming that the error is in the (defun... line itself.  Farther down, I noticed this:
  (princ "\nhere")  ;;; <--- this is the 'then' argument
  (progn  ;;; <--- you intend this to be the 'then' argument, but it's really the 'else' argument
  (setq ss (ssget "_I"  ;;; <--- you intend this to be the 'else' argument, but it's really a third argument that (if) can't have
Kent Cooper, AIA
Jonathan_Bell82GXG
Whoops thanks! I added in some print statements for debugging something else
