define auto plot area
tarin_lc
tarin_lc
Hello
I want to create a feature that automatically determines the print area relative to the XYmin and XYmax points in a dynamic block.
I can extract the coordinates of these points but I can't determine the plot area according to these points. I'd also like, in the long run, to force a PC3 printer (PDF. PC3) and choose a paper size automatically in relation to the calculation of points. For example, xmax - xmin = 420, ymax - ymin = 297 => A3, etc...
thanks for all,
Sea-Haven
A couple of questions like others, do plot titles, are there multiple blocks in Model space that you want to plot or are you using one title block per layout ?
Sample code of a plot lisp.
   (COMMAND "-PLOT"  "Y"  "" "Plot To PDF"
	       "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE"  "N"   "W"  "-6,-6" "807,560" "1=2"  "C"
	       "y" "Acad.ctb" "Y"	"n" "n" "n" pdfName "N" "y"
If you can post a dwg.
