Define and insert blocks with attributes , using DXF codes and AutoLisp
Message 1 of 61
Hello everyone !
I am trying to define a block with attributes with LockPosition = On , using DXF codes (280 . 1)  and AutoLisp (lisp c: TestPP attached below ) . For Visual Lisp , property LockPosition = Read Only , so can't be changed !
The problem is , this (280 . 1)  is having effect only if I introducing codes 100 in blue . But then , I have a problem with TextStyle (7 . "ArialT")  .
(defun c:TestPP ()
 (prinC "\n  TestPP  :  V  :  1 . 04 . 2019  ;")
 (setVar "TextStyle" "Standard")
 (vl-CmdF "_.Purge" "_A" "" "_N")
 (if (tblSearch "Block" "PxT")
  (princ "\n  Block  Existed !")
  (progn ; Define Block
   (command "_.Layer" "_N" "Name L" "_C" 1 "Name L" "")
;;;   (if (tblSearch "Style" "ArialT") T (vl-CmdF "_.Style" "ArialT" "Arial.ttf" 0 1 0 "_N" "_N") ) ;
;;;   (if (not (tblobjname "Style" "ArialT")) (vl-CmdF "_.Style" "ArialT" "Arial.ttf" 0 1 0 "_N" "_N") ) ;
;;;   (if (not (tblobjname "Style" "ArialT")) (vl-CmdF "-Style" "ArialT" "Arial.ttf" 0 1 0 "_N" "_N") ) ;
   (if (not (tblSearch "Style" "ArialT")) (vl-CmdF "-Style" "ArialT" "Arial.ttf" 0 1 0 "_N" "_N") ) ;
;;;   (cond ( (null (tblSearch "STYLE" "ELEV_ARIAL_1"))
;;;          (setq nw_style (vla-Add (vla-get-textStyles (vla-get-ActiveDocument (vlax-get-acad-Object))) "ArialT")
;;;                nw_font (strcat (getEnv "systemroot") "\\Fonts\\Arial.ttf")
;;;          ) ;end_setq
;;;          (mapcar '(lambda (pr val) (vlax-put-Property nw_style pr val))
;;;            (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
;;;            (list nw_font 0.0 (/ (* 0.0 pi) 180) 1.0 0.0)
;;;          ) ;end_mapcar
;;;   ) ;end_cond
   (entMake '((0 . "BLOCK") (2 . "PxT") (70 . 2) (8 . "0") (10 0 0 0) (6 . "ByLayer") (62 . 256) (4 . "Made by Me"))  ) ; end of e
   (entMake (list '(0 . "Circle") '(8 . "0") '(62 . 256) '(6 . "ByLayer") '(10 0 0 0) (cons 40 0.25) ) ) ; end of e
   (entMake (list '(0 . "AttDef") '(100 . "AcDbEntity") (cons 8 "Name L") '(62 . 256) '(6 . "ByLayer") ;'(67 . 0)
                  '(100 . "AcDbText") '(10 0 0 0) '(40 . 1.5) '(1 . "N") '(50 . 0) '(41 . 1) '(51 . 0) '(7 . "ArialT") '(71 . 0) '(72 . 0)
                            '(11 0.5 +1.0 0) '(210 0.0 0.0 1.0)
                  '(100 . "AcDbAttributeDefinition") '(280 . 0) '(3 . "Point Name") '(2 . "NAME") '(70 . 0) '(73 . 0) '(74 . 2) '(280 . 1) ) ) ; end of e  ;'(100 . "AcDbXrecord")
   (entMake '((0 . "EndBlk") (8 . "0")) ) ; end of e
   (prinC "\n   Block  with  Attributes  DEFINED  :  PxT  ;") ; end of p
  ) ; else
 ) ; if
 (setq ;q (getString "\n   Attribute  Insertion  with  Codes  100  :  Any = NO  ;   <  Enter = YES  >  :  ")
       i 0)
 (repeat 10 ; Inserting 10 Blocks with Attribute
  (entMake (list '(0 . "Insert") '(2 . "PxT") '(8 . "0") '(66 . 1) (cons 10 (trans (list i i i) 1 0)) '(50 . 0) '(41 . 1.0) '(42 . 1.0) '(43 . 1.0)) ) ; inserare Bloc
  (if (= (rem i 2) 0) ;(= q "")
  (entMake (list '(0 . "ATTRIB") '(100 . "AcDbEntity") '(8 . "Name L") '(67 . 0) ;'(6 . "ByLayer") ;'(62 . 256) '(67 . 0) ;0 = MSpace ;
                 '(100 . "AcDbText") (list 10 i i i) '(40 . 1) (cons 1 (ItoA i)) '(50 . 0) '(41 . 1.0) '(51 . 0.0)  '(7 . "ArialT")
                        '(71 . 0) '(72 . 0) (cons 11 (trans (list i i i) 1 0)) ;'(210 0.0 0.0 1.0)
                 '(100 . "AcDbAttribute") '(280 . 0) '(2 . "NAME") '(70 . 0) '(73 . 0) (cons 74 2) '(280 . 1) )  ) ; set Attribute
  (entMake (list '(0 . "ATTRIB") (list 10 i i i)  '(8 . "Name L") (cons 1 (ItoA i)) '(280 . 0) '(2 . "NAME") '(40 . 1) '(70 . 0)
             (cons 11 (trans (list i i i) 1 0)) (cons 72 0) (cons 74 2) '(6 . "ByLayer") '(7 . "ArialT") '(50 . 0) '(62 . 5) '(280 . 1) )  ) ; e
  ) ; if
  (entMake '((0 . "SeqEnd") (8 . "0")) ) ; End Insert Block !
  (setq i (1+ i))
 ) ; r
 (setVar "TextStyle" "Standard") (command "zoom" "e")
 (prinC (strCat "\n   Inserted  :  " (ItoA i) "  ;"))
 (prinC "\n   TestPP  :  END  ;") (prinC)
) ; defun c:TestPP
I create a condition which is alternating the insertion of the attributes .
Open a new dwg , load and run the lisp . The only difference will be too many grips for blue and odd numbers , because (280 . 1) is not having any effect .
Delete all and run the lisp again . Only the blue and odd attributes are visible .
For a manual insertion , TextStyle for attribute is Standard .
So , at the same time , the same block can have different appearances / properties as : color , height , layer rotation , etc .
If I keep the TextStyle ArialT preserved in the drawing , as current Text Style or used somewhere else , are NO problems .
Any idea ?
Thanks in advance .
Replies (60)
Message 2 of 61
Moshe-A
@Anonymous  hi,
you are right, it seems that dxf code 280 can not be changed but it is not read only cause you can change it with ActiveX.
using (entmake) it's better to include the minimum dxf codes that needed to construct the entity and skip the codes with default values.
here is my fixed code and it works Smiley LOL
enjoy
moshe
(defun c:TestPP (/ attdef_lock_position ; local function
		   bname)
 (defun attdef_lock_position (/ AcDbBlockTableRecord)
  (setq AcDbBlockTableRecord (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) bname))
  (vlax-for AcDbEntity AcDbBlockTableRecord
   (if (eq (vla-get-objectName AcDbEntity) "AcDbAttributeDefinition")
    (vlax-put AcDbEntity 'lockPosition :vlax-true)
   (vlax-release-object AcDbEntity)
  (vlax-release-object AcDbBlockTableRecord)
 ); attdef_lock_position
;;;          ) ;end_setq
;;;          ) ;end_mapcar
;;;   ) ;end_cond
   (entMake (list '(0 . "Circle") '(8 . "0") '(62 . 256) '(6 . "ByLayer") '(10 0.0 0.0 0.0) '(40 . 0.25) ) ) ; end of e
   (entMake (list '(0 . "ATTDEF") '(8 . "Name L") '(62 . 256) '(6 . "ByLayer") ;'(67 . 0)
                  '(10 0.0 0.0 0.0) '(40 . 1.5) '(1 . "N") '(50 . 0) '(41 . 1) '(51 . 0) '(7 . "ArialT") '(71 . 0) '(72 . 0)
                  '(11 0.5 1.0 0.0) '(210 0.0 0.0 1.0) '(3 . "Point Name") '(2 . "NAME") '(70 . 0) '(73 . 0) '(74 . 2))) ; end of e  ;'(100 . "AcDbXrecord")
   (setq bname (entMake '((0 . "EndBlk") (8 . "0")))) ; end of e
  ) ; else
 ) ; if
       i 0)
   (entMake (list '(0 . "ATTRIB") '(8 . "Name L") '(67 . 0) ;'(6 . "ByLayer") ;'(62 . 256) '(67 . 0) ;0 = MSpace ;
                 '(2 . "NAME") '(70 . 0) '(73 . 0) '(74 . 2))) ; set Attribute
   ; else
   (entMake (list '(0 . "ATTRIB") (list 10 i i i)  '(8 . "Name L") (cons 1 (ItoA i)) '(2 . "NAME") '(40 . 1) '(70 . 0)
                   (cons 11 (trans (list i i i) 1 0)) '(72 . 0) '(74 . 2) '(6 . "ByLayer") '(7 . "ArialT") '(50 . 0) '(62 . 5))) ; e
  ) ; if
  (entMake '((0 . "SEQEND") (8 . "0")) ) ; End Insert Block !
  (setq i (1+ i))
 ) ; r
) ; defun c:TestPP
Message 3 of 61
Thank you very much Moshe-A ,
You need to introduce and call your function attdef_lock_position somewhere in the lisp
(vlax-put AcDbEntity "LockPosition" :vlax-true)
it is available only for definition of a block , in "ATTDEF" .
It is necessary to apply this setting again , for all attributes in the insertion process , for "ATTRIB" .
Otherwise ,  LockPosition will be OFF , as in the attached picture and dwg .
Unfortunately ,
_$ (vlax-dump-object attV T)
; IAcadAttributeReference: AutoCAD Attribute Reference Interface
; Property values:
;   LockPosition (RO) = -1 ; READ ONLY !
;   ObjectName (RO) = "AcDbAttribute"
;   StyleName = "ArialT"
So , can't be used :
(vla-put-LockPosition attV :vlax-true)
Only (280 . 1) it is working , but only together with all 100's codes : (100 . "AcDbAttribute") ...
Run the lisp , and after that use next code :
(setq b (entlast)  a1 (entnext b)  attV (vlax-ename->Vla-Object a1)  lA1 (entget a1) )
I am still thinking , maybe this (7 . "ArialT") should be followed by special code , or should be in the other position .
The TextStyle (7 . "ArialT") . it is having effect only after (100 . "AcDbText") .
I have attached as well a pdf file for DXF description for AutoCAD 2009 , page 79 . In this book , code 7 : (7 . "ArialT")
it is part of (100 . "AcDbAttribute") . I have tried , but is not working at all .
Anyway , It is very strange !
Message 4 of 61
Moshe-A
@Anonymous ,
first my apology about miss call to (attdef_lock_position) function, it's was very late and want to go to bed (but it popup over my sleep)
i also did not have success in locking the position and it's true it is weird but why insist? if it does not work this way go with another, use (command "insert")
moshe
Message 5 of 61
Hello Moshe ,
I really need this,  because I am using it many times per day.
A command "insert" .... will be very slow for 5000 blocks .
I find 2 tricks:
1. Preserve the text style as curent.
(SetVar "TextStyle" "ArialT")
Do not be PURGE !
2. Remove (7 . "ArialT") from insertion,  and use Visual Lisp to change the Text Style = Standard in to "ArialT" , again  for 4 Attributes.
Should be the right way somehow.
Message 6 of 61
dbhunia
Try this way ....... (Roughly checked)
(defun c:TestPP ()
 ;(setVar "TextStyle" "Standard")
  (princ "\nBlock  Existed !\n")
  ) ; else
 ) ; if
       i 0)
                 '(71 . 0) '(72 . 0) (cons 11 (trans (list i i i) 1 0)) '(62 . 5) ;'(210 0.0 0.0 1.0)
  ) ; if
  (setq i (1+ i))
 ) ; r
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 7 of 61
Moshe-A
here is your solution ...  at the end of your lisp command call BATTMAN (only once)
Message 8 of 61
Thank you very much dbhunia .
I know this trick , but I am looking for a solution .
At the moment , I am preserving the TextStyle "ArialT" as the current one .
(setVar "TextStyle" "ArialT")
But , if I will use a different TextStyle as current , after PURGE command , I will lose my "ArialT" .
And will not work againe .
Regards ,
Costin
Message 9 of 61
Moshe-A
sorry, meant ATTSYNC
Message 10 of 61
Hello Meshe ,
1. try to use ATTSYNC on attached dwg , and you will see the problem .
Unfortunately , ALL the Attributes will jump on the right side .
2. try to use ATTSYNC on the second attachment 'Test 3 .dwg' . Is not working .
Message 11 of 61
Moshe-A
of course it jumps cause attsync synchronize what is defined in the block definition
to solve this,  consider to create 2 blocks with attributes locked on each side.
Message 12 of 61
Unfortunately , are more than 2 positions.
Picture attached .
Message 13 of 61
It is a conflict in the next code , between Textstyle "ArialT" and "ATTRIB" DXF definition .
(7 . "ArialT") should be in another location or ...?
Because , with (7 . "Standard") , it is absolutely NO problem .
Next code is running all the time fine :
But , unfortunately , (280 . 1) is not applying .
How ? Why ? Are the same settings , but in a slightly different way .
Message 14 of 61
Moshe-A
you can not have it all
i tried locking the attributes layers and even then ATTSYNC caused them to jump
Message 15 of 61
Moshe-A
maybe it is related to true type fonts
does it works with shx?
Message 16 of 61
CADaSchtroumpf
This example (make with your drawing) can help you?
(defun c:BlockAttPT ( / );(num lst_posatt dxf_210 pto x y z ang pos_att)
	(cond
		((eq (getvar "cvport") 1)
			(princ "\n** Only in space object.")
		(T
			(if (not (tblsearch "STYLE" "ArialTopo"))
				(entmake
					(0 . "STYLE")
					(5 . "40")
					(100 . "AcDbSymbolTableRecord")
					(100 . "AcDbTextStyleTableRecord")
					(2 . "ArialTopo")
					(70 . 0)
					(40 . 0.0)
					(41 . 1.0)
					(50 . 0.0)
					(71 . 0)
					(42 . 2.5)
					(3 . "arial.ttf")
					(4 . "")
			(if (not (tblsearch "BLOCK" "PunctT"))
				(progn
					(entmake
						'((0 . "BLOCK") (2 . "PunctT") (70 . 2) (8 . "0") (62 . 256) (6 . "ByLayer") (370 . -2) (10 0.0 0.0 0.0))
					(entmake
							(0 . "LWPOLYLINE")
							(67 . 0)
							(410 . "Model")
							(8 . "0")
							(100 . "AcDbPolyline")
							(90 . 5)
							(70 . 0)
							(43 . 0.0)
							(38 . 0.0)
							(39 . 0.0)
							(10 0.353553 0.353553)
							(40 . 0.0)
							(41 . 0.0)
							(42 . 0.0)
							(91 . 0)
							(10 -0.353553 -0.353553)
							(40 . 0.0)
							(41 . 0.0)
							(42 . 0.0)
							(91 . 0)
							(10 0.0 0.0)
							(40 . 0.0)
							(41 . 0.0)
							(42 . 0.0)
							(91 . 0)
							(10 0.353553 -0.353553)
							(40 . 0.0)
							(41 . 0.0)
							(42 . 0.0)
							(91 . 0)
							(10 -0.353553 0.353553)
							(40 . 0.0)
							(41 . 0.0)
							(42 . 0.0)
							(91 . 0)
							(210 0.0 0.0 1.0)
					(entmake
							(0 . "CIRCLE")
							(67 . 0)
							(410 . "Model")
							(8 . "0")
							(100 . "AcDbCircle")
							(10 0.0 0.0 0.0)
							(40 . 0.25)
							(210 0.0 0.0 1.0)
					(entmake
							(0 . "ATTDEF")
							(67 . 0)
							(410 . "Model")
							(8 . "0 Point Name")
							(100 . "AcDbText")
							(10 0.5 0.25 0.0)
							(40 . 1.5)
							(1 . "")
							(50 . 0.0)
							(41 . 1.0)
							(51 . 0.0)
							(7 . "ArialTopo")
							(71 . 0)
							(72 . 0)
							(11 0.5 1.0 0.0)
							(210 0.0 0.0 1.0)
							(280 . 0)
							(3 . "Dati DENUMIRE Punct  : ")
							(2 . "DENUMIRE")
							(70 . 0)
							(73 . 0)
							(74 . 2)
							(280 . 1)
					(entmake
							(0 . "ATTDEF")
							(67 . 0)
							(410 . "Model")
							(8 . "0 Point Height")
							(100 . "AcDbText")
							(10 0.5 -1.75 0.0)
							(40 . 1.5)
							(1 . "")
							(50 . 0.0)
							(41 . 1.0)
							(51 . 0.0)
							(7 . "ArialTopo")
							(71 . 0)
							(72 . 0)
							(11 0.5 -1.0 0.0)
							(210 0.0 0.0 1.0)
							(280 . 0)
							(3 . "Dati COTA Punct  : ")
							(2 . "COTA")
							(70 . 0)
							(73 . 0)
							(74 . 2)
							(280 . 1)
					(entmake
							(0 . "ATTDEF")
							(67 . 0)
							(410 . "Model")
							(8 . "0 Point Code")
							(100 . "AcDbText")
							(10 0.5 0.025 0.0)
							(40 . 0.15)
							(1 . "")
							(50 . 0.0)
							(41 . 1.0)
							(51 . 0.0)
							(7 . "ArialTopo")
							(71 . 0)
							(72 . 0)
							(11 0.5 0.1 0.0)
							(210 0.0 0.0 1.0)
							(280 . 0)
							(3 . "Dati COD Punct  : ")
							(2 . "COD")
							(70 . 0)
							(73 . 0)
							(74 . 2)
							(280 . 1)
					(entmake
							(0 . "ATTDEF")
							(67 . 0)
							(410 . "Model")
							(8 . "0 Point Description")
							(100 . "AcDbText")
							(10 0.5 -0.175 0.0)
							(40 . 0.15)
							(1 . "")
							(50 . 0.0)
							(41 . 1.0)
							(51 . 0.0)
							(7 . "ArialTopo")
							(71 . 0)
							(72 . 0)
							(11 0.5 -0.1 0.0)
							(210 0.0 0.0 1.0)
							(280 . 0)
							(3 . "Dati DESCRIERE Punct  : ")
							(2 . "DESCRIERE")
							(70 . 0)
							(73 . 0)
							(74 . 2)
							(280 . 1)
					(entmake '((0 . "ENDBLK") (8 . "0") (62 . 256) (6 . "ByLayer") (370 . -2)))
			(initget "Rigth Left")
			(if (eq (getkword "\nAt Rigth or Left? [Rigth/Left]<Rigth>: ") "Left")
				(setq lst_posatt '((-0.05 0.10 0.0) (-0.05 -0.1 0.0) (-0.05 0.01 0.0) (-0.05 -0.01 0.0)))
				(setq lst_posatt '((0.05 0.10 0.0) (0.05 -0.1 0.0) (0.05 0.01 0.0) (0.05 -0.01 0.0)))
			(setq num 0 dxf_210 (trans '(0 0 1) 1 0 T))
			(while (setq pto (getpoint "\nInsertion point: "))
				(setq
					x (car pto)
					y (cadr pto)
					z (caddr pto)
					ang 0.0
					pos_att (mapcar '(lambda (x) (polar (trans '(0.0 0.0 0.0) dxf_210 0) (+ (angle (trans '(0.0 0.0 0.0) dxf_210 0) (trans x dxf_210 0)) ang) (distance (trans '(0.0 0.0 0.0) dxf_210 0) (trans x dxf_210 0)))) lst_posatt)
				(entmake
					(append
							(0 . "INSERT")
							(67 . 0)
							(410 . "Model")
							(8 . "0 Point Symbol")
							(100 . "AcDbBlockReference")
							(66 . 1)
							(2 . "PunctT")
							(41 . 0.1)
							(42 . 0.1)
							(43 . 0.1)
							(50 . 0.0)
							(70 . 0)
							(71 . 0)
							(44 . 0.0)
							(45 . 0.0)
						(list (cons 10 (trans pto 0 dxf_210)) (cons 210 dxf_210))
				(entmake
					(append
							(0 . "ATTRIB")
							(67 . 0)
							(410 . "Model")
							(100 . "AcDbText")
						(list
							(cons 10 (trans (list (+ (car pto) (caar pos_att)) (+ (cadr pto) (cadar pos_att)) (+ (caddr pto) (caddar pos_att))) 0 dxf_210))
							(cons 1 (itoa (setq num (1+ num))))
							(40 . 0.15)
							(50 . 0.0)
							(41 . 1.0)
							(51 . 0.0)
							(7 . "ArialTopo")
							(71 . 0)
						(list
							(if (< (caar pos_att) 0)
								'(72 . 2)
								'(72 . 0)
							(cons 11 (trans (list (+ (car pto) (caar pos_att)) (+ (cadr pto) (cadar pos_att)) (+ (caddr pto) (caddar pos_att))) 0 dxf_210))
							(cons 210 dxf_210)
							(280 . 0)
							(2 . "DENUMIRE")
							(70 . 0)
							(73 . 0)
							(74 . 2)
							(280 . 0)
				(setq pos_att (cdr pos_att))
				(entmake
					(append
							(0 . "ATTRIB")
							(67 . 0)
							(410 . "Model")
							(100 . "AcDbText")
							(10 554053.0 336372.0 0.0)
							(40 . 0.15)
							(50 . 0.0)
						(list
							(cons 1 (rtos z 2 3))
							(41 . 1.0)
							(51 . 0.0)
							(7 . "ArialTopo")
							(71 . 0)
						(list
								'(72 . 2)
								'(72 . 0)
							(cons 210 dxf_210)
							(280 . 0)
							(2 . "COTA")
							(70 . 0)
							(73 . 0)
							(74 . 2)
							(280 . 0)
				(entmake
					(append
							(0 . "ATTRIB")
							(67 . 0)
							(410 . "Model")
							(100 . "AcDbText")
						(list
							(cons 1 (rtos 52.00 2 2))
							(40 . 0.015)
							(1 . "52.00")
							(50 . 0.0)
							(41 . 1.0)
							(51 . 0.0)
							(7 . "ArialTopo")
							(71 . 0)
						(list
								'(72 . 2)
								'(72 . 0)
							(cons 210 dxf_210)
							(280 . 0)
							(2 . "COD")
							(70 . 0)
							(73 . 0)
							(74 . 2)
							(280 . 0)
				(entmake
					(append
							(0 . "ATTRIB")
							(67 . 0)
							(410 . "Model")
							(100 . "AcDbText")
						(list
							(40 . 0.015)
							(1 . "Taluz Dr /= 52 S")
							(50 . 0.0)
							(41 . 1.0)
							(51 . 0.0)
							(7 . "ArialTopo")
							(71 . 0)
						(list
								'(72 . 2)
								'(72 . 0)
							(cons 210 dxf_210)
							(280 . 0)
							(2 . "DESCRIERE")
							(70 . 0)
							(73 . 0)
							(74 . 2)
							(280 . 0)
				(entmake '((0 . "SEQEND") (62 . 256) (6 . "ByLayer") (370 . -2)))
	(prin1)
Message 17 of 61
no , with ttf
(vl-CmdF "-Style" "ArialT" "arial.ttf" 0 1 0 "_N" "_N")
or
(entMake (list '(0 . "STYLE") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbTextStyleTableRecord") '(2 . "ArialT") '(70 . 0) '(40 . 1.0) '(41 . 1.0) '(50 . 0.0) '(71 . 0) '(3 . "arial.ttf") '(4 . "")))
No matter , is the same problem at the end .
Message 18 of 61
Thank you very much  CADaStroumph .
Run the next code in a new drawing :
(defun c:TestPP ()
;;; (if (tblSearch "Style" "ArialTopo") (setVar "TextStyle" "ArialTopo"))
;;;   (if (not (tblSearch "Style" "ArialT")) (vl-CmdF "-Style" "ArialT" "arial.ttf" 0 1 0 "_N" "_N") ) ;
;;;(if (not (tblSearch "Style" "ArialT")) (entMake (list '(0 . "STYLE") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbTextStyleTableRecord") '(2 . "ArialT") '(70 . 0) '(40 . 1.0) '(41 . 1.0) '(50 . 0.0) '(71 . 0) '(3 . "arial.ttf") '(4 . ""))) )
                  '(71 . 0) '(72 . 0) '(11 0.5 +1.0 0) '(210 0.0 0.0 1.0)
                  '(100 . "AcDbAttributeDefinition") '(280 . 0) '(3 . "Point Name") '(2 . "NAME") '(70 . 0) '(73 . 0) '(74 . 2) '(280 . 1) ) ) ; end of e  '(100 . "AcDbXrecord")
  ) ; else
 ) ; if
       i 0)
;;; (setVar "TextStyle" "ArialT")
  ) ; if
  (setq i (1+ i))
 ) ; r
) ; defun c:TestPP
delete ALL and run again .
This is the problem , the red attributes have a problem .
So , how it is working on the first time and not after ?
Regards ,
Costin
Message 19 of 61
CADaSchtroumpf
A priori in your code is the assignment of ArialT style when there is parity of the number that does not do well.
if you make an eattedit on an absent attribute and you go into the text options, no style is affected.
with the good style, the tag is come-back
Message 20 of 61
Moshe-A
consider dealing this with anonymous blocks (much the same as AutoCAD deals with dimensions) BATTMAN\ATTSYNC does not affect them. this means that each block reference (insert) will have it's own block definition and the dwg size would be increase accordingly.
