@markruys2 wrote:any functions which transform a decimal number to hexadecimal and vice versa?
You'll find lots of approaches if you search the forum for "hexadecimal," and if you like, add "handle" to the search terms, since entity handles are hexadecimal numbers, and various threads that have converters are about things like sorting drawing order by handles.
As part of some encompassing routines I posted on a thread called "making a block unique?" last August, here's a hex-to-integer converter I simplified somewhat from a more generic converter of Frank Oquendo's:
;; hex2int.lsp - Hexadecimal to base-10 Integer converter [e.g. for entity handles]
(defun hex2int (hndl / result power tmp)
;; modified from Frank Oquendo's (basetodecimal) function
(setq
hndl (strcase hndl)
result 0
); end setq
(repeat (setq power (strlen hndl))
(setq result
result
(setq tmp (ascii (substr hndl 1 1)))
(if (> tmp 64) 55 48)
); end -
(expt 16 (setq power (1- power)))
); end *
); end +
hndl (substr hndl 2)
); end setq
); end repeat
result
); end defun - hex2int
Since that was about converting handles, there wasn't any need to go the other way, so I'd have to think about that. If you don't find a decimal-to-hex converter elsewhere, write back.
Take a look at these two old routines from Reini Urban if you don't find any better:
(defun STD-NUM->HEX (i / s a) (setq s "") (while (> i 0) (setq a (rem i 16) i (lsh i -4) ) ;_ setq (setq s (strcat (if (< a 10) (chr (+ 48 a)) ; 48: (ascii "0") (chr (+ 55 a)) ) ;_ if s ) ;_ strcat ) ;_ setq ) ;_ while ) ;_ defun (defun STD-HEX->NUM (s / i n a) ;(std-%simple-require "STDSTR") (setq i 0 n 0 ;s (std-strcase s) s (strcase s) ) (if (= (substr s 1 2) "0X") (setq s (substr s 3)) ) ;_ if (while (< i (strlen s)) (setq a (substr s (setq i (1+ i)) 1)) (if (not (<= "0" a "F")) (chr a) ) (setq n (+ (lsh n 4) (- (ascii a) (if (<= a "9") 48 55 ) ;_ if ) ;_ - ) ;_ + ) ;_ setq ) ;_ while ) ;_ defun
I think they still work.
I came up with the attached integer-to-hexadecimal converter, and modified that earlier hexadecimal-to-integer converter, so that both have input-validity controls, and the capacity to handle, for the integer-to-hex one, zero [which Reini Urban's STD-NUM->HEX routine that JustoAg posted doesn't like], and for both, negative numbers [which none of the routines posted here so far convert correctly].
Now when you say "decimal," do you really mean that -- that is, do you want to be able to convert non-integer values? There is the possibility of decimal places in non-base-10 numbering systems, after all. An AutoCAD entity handle would never have that, but that needn't be a limiting factor. Another level of complexity, but it could be done, I suppose.
actually i need positive integers only, but never know what the future brings...
thanks again
m
Hey I found some hexa to decimal converter with auto apply. It has som basic UI
