debugging with VLISP editor. Thanks
Message 1 of 8
Hi, guys!
I have an issue regarding debugging with VLISP editor
I use the following tutorial
http://www.lee-mac.com/debugvlide.html#where.
I copy-paste text into editor
I run it and I supposed to receive the message
; error: bad argument type: lentityp nil
But I get the the result of the function: nil
All ideas are appreciated.
Replies (7)
Message 2 of 8
@ВeekeeCZ, thanks for reply.
Please explain what do you mean?
My function
is
(defun C:MyX ( / n)
	(setq n 3)
  (princ n)
	;(setq MyLength fret  )
This is what I get in VLIST Console
; 2 forms loaded from #<editor "C:/Users/psuzd_000/Documents/AutoLisp/fret formula.LSP">
_$ MYX
nil
_$
Thanks!
Message 3 of 8
But if I enter command in console
(set q 10)
(Princ q)
It works fine
Message 4 of 8
ВeekeeCZ
I see your point now 🙂
I never use the console, I always test my program from the command line. So I don't have this experience. But as I can see in help, there are some differences.
But anyway... Lee's totorial interacts with autocad enviroment (you need select lines), so load it a run it from Autocad.In this case Lee's code fails as expected 🙂
Message 5 of 8
Yes, I do the same, I test code from the autocad command line.
But I hopped to ease the process.
Hope, someone else can help.
Anyway, thanks!
Message 6 of 8
hmsilva
Anyway, thanks!
Hi s.shivaprem,
you'll have to call the function in VLISP editor...
Try to call:
(c:myx)
Hope this helps,
Henrique
Message 7 of 8
Yes, it works!
Yes, it helps!
Thanks!
Message 8 of 8
hmsilva
@Anonymous wrote:
Yes, it works!
Yes, it helps!
Thanks!
You're welcome, s.shivaprem
Glad I could help
Henrique
