Deactivate Multiple Tiles with Single Toggle
jcpLPAKD
Message 1 of 10
jcpLPAKD
I have three edit boxes that I want to be able to disable with the click of a single toggle. All of these lines will work on their own but when run together only the list line is executed.
  (action_tile "tg1" "(setq result $key) (mode_tile \"eb1\" (- 1 (atoi $value))))")
  (action_tile "tg1" "(setq result $key) (mode_tile \"eb1a\" (- 1 (atoi $value))))")
  (action_tile "tg1" "(setq result $key) (mode_tile \"eb1b\" (- 1 (atoi $value))))")
Is there a way to combine these 3 lines into one?
Thanks in advance!
Replies (9)
Message 2 of 10
paullimapa
put all the action call back functions into one line only and not separate lines that's what's causing the problem because AutoCAD doesn't support multiple callbacks
(action_tile "tg1" "(setq result $key) (mode_tile \"eb1\" (- 1 (atoi $value)))(mode_tile \"eb1a\" (- 1 (atoi $value)))(mode_tile \"eb1b\"(- 1 (atoi $value)))")
Paul Li
IT Specialist
@The Office
Message 3 of 10
Moshe-A
@jcpLPAKD hi,
(action_tile key action-expression)
Lets take a look at the second argument of (action_tile) function.
it says action-expression (as a string) - yes?
action-expression means any AutoLISP symbol (variable or a function)
and function in this case means a callback function. as soon as you click on the tile (action-tile) will fire callback.
instead of writing an endless code in one line (which of course is legal) you could do:
; callback function
(defun enable_disable_editbox (val)
   (foreach key '("eb1" "eb2" "eb3")
     (mode_tile key (itoa (1- (atoi val))))
(action_tile "tg1" "(enable_disable_editbox $value)")
this way the code is very clear, simple and easy to debug - no? 😀
enjoy
Moshe
Message 4 of 10
jcpLPAKD
Worked perfectly.
Message 5 of 10
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Message 6 of 10
jcpLPAKD
I like the more compact code but I can't get it to work.  It keeps failing at:
When checking the toggle I get the error 'Bad argument type: fixnump: "0"  '
When unchecking the toggle I get the error 'Bad argument type: fixnump: "-1"
Is val supposed to be defined?
Message 7 of 10
paullimapa
the error occurs when your tile is already disable which returns a value of 0 and your code then applies a subtraction of -1 causing it to now return a negative #. To disable just use 0
(mode_tile key 0)
to enable use 1
(mode_tile key 1)
Paul Li
IT Specialist
@The Office
Message 8 of 10
komondormrex
try this. 1- function replaced with - function
					(foreach tile '("eb1" "eb1a" "eb1b")
						(mode_tile tile (- 1 (atoi $value)))
Message 9 of 10
jcpLPAKD
Ok, I finally figured out why this callback function was not working.  The minus sine is in the wrong place and iota is not necessary.
This is the corrected code.
   (mode_tile key (- 1 (atoi val)))
Thanks for all the help with this!
Message 10 of 10
Moshe-A
@jcpLPAKD ,
The minus sign is in right place, cause (1- n) is accepable expresstion in autolisp. the (itoa) function is not nessacery here and that is the result of repling here when you do not have a working AutoCAD under hand 😀
so the following is also correct:
   (mode_tile key (1- (atoi val)))
Althought i'm not rewarded here 😂, i'm glade to see you finally choose to use my solution 😀
cheers
Moshe
