DCL wtf?
DCL wtf?
Message 1 of 10
DCL wtf?
Hi all!
I just started to learn DCL.
https://www.afralisp.net/dialog-control-language/tutorials/getting-started-part-1.php
Im doing this tutorial.
I copied the dcl code into a dcl file. I copied the lisp code into an lsp file. I named them the same. (test_dcl1) and i put them in the same (trusted) directory.
I loaded the lsp, get the prompt.
I entered test_dcl1 and it ends with:
; error: quit / exit abort
Can someone try this? Is it working?
What am i doing wrong?
Do i have to download something to use DCL? I didnt see anything regarding i would have to download anything....
Thanks in advance
Replies (9)
Message 2 of 10
_Tharwat
Try this updated lisp for you to know where the problem resides if it took a place.
(defun C:TEST_DCL1 (/ dcl_id )
 (if (and (or (findfile "test_dcl1.dcl")
              (alert "Dcl file < test_dcl1.dcl > was not found")
          (setq dcl_id (load_dialog "test_dcl1.dcl"))
          (or (< 0 dcl_id)
              (alert "Dcl file could not be loaded")
          (or (new_dialog "test_dcl1" dcl_id)
              (alert "Press Ok to exit safely")
   (progn
     (action_tile "accept" "(done_dialog)")
     (start_dialog)
     (unload_dialog dcl_id)
  (princ)
Message 3 of 10
I tried it, the first one is the problem. Ive got the alert message about the DCL file was not found.
I dont understand why because its in the same directory and named the same as the lsp file. 😞
Message 4 of 10
_Tharwat
What you think is trusted was not trusted. 😉
Move the DCL file into your AutoCAD Support folder and that should guarantee the file to be found.
Message 5 of 10
And really this helped 😮 Thanks very much!
And this is insane. Now i loaded the file from the original directory again and now its working that one also... And i havent changed anything... 😄
Message 6 of 10
_Tharwat
You're welcome anytime.
No worries, this should happen from time to time so be prepared for more. 😄
Happy coding.
Message 7 of 10
john.uhden
I have the opinion that you should not comingle your custom code in with all the AutoCAD code.
Instead:
1.  Make a directory, say c:\Custom.
2.  In Options -> Support File Search Path, add C:\Custom
3.  Run this, just once...
     (setvar "trustedpaths" (strcat (getvar "trustedpaths") ";C:\\Custom"))
Now you won't have to worry about AutoCAD needing a path to your custom files.  In fact you won't need to supply any path at all, provided your files are uniquely named.
If you have an acaddoc.lsp file, or want to create one, put it in the c:\Custom folder.  AutoCAD will find and load it automatically.
If you are in doubt as to whether a file name is unique, at the command prompt enter (findfile "<myfilename.dcl>").  AutoCAD will return either the name of the file including path (if found) or nil (if not found).
Enjoy, or else!
John F. Uhden
Message 8 of 10
Sea-Haven
Nice idea John explaining how to add paths has many scratching their heads, a copy and paste to add C:\custom.
(setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-Acad-object))))
(vla-put-SupportPath *files* (strcat "c:\\Custom;"(vla-get-SupportPath *files*) ))
Message 9 of 10
john.uhden
@Sea-Haven
True.  I did not say where to add the path.
I see that you are suggesting to put it first in the list.
Other than that, there really ain't no diff.
John F. Uhden
Message 10 of 10
Thanks very much! 🙂
