DCL popup_list looks like a button
C.Utzinger
Message 1 of 9
C.Utzinger
HI
I'm using a popup_list and it looks like a button, but i want to have it like a white field.
Should i do that with edit_box?
Please, need a little help...
Replies (8)
Message 2 of 9
rkmcswain
Perhaps you want a list_box instead of a popup_list?
list_boxlist_box
popup_listpopup_list
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 9
C.Utzinger
I want this:
I have this (popup_list)
Kind regards
Message 4 of 9
rkmcswain
The actual rendering of the various controls is dependent on the platform you are running (Windows, Mac, Sun, etc.) AFAIK, there is no more control that what you have on the DCL side of things.
Message 5 of 9
C.Utzinger
OK thank you.
Both images are from the same system and AutoCAD.
Kind regards.
Message 6 of 9
rkmcswain
Are both of them using the same DCL code?
Message 7 of 9
C.Utzinger
No. the other one is from another Programm I use for AutoCAD. Perhaps it's not a DCL.
Message 8 of 9
paullimapa
Looks like you have this combination of text label with edit_box and popup_list.
But I believe AutoCAD when reading DCL will always show the popup_list with a grey background and not a white one.
test : dialog {
: row {
  : text {
    label = "Massstab:";
  : edit_box {
    label = "1:";
    value = "50";
    key = "massstab";
    mnemonic = "1";
    edit_width = 13;
    width = 13;
 : popup_list {
   label = "Einheiten";
   value = "0";
   key = "einheiten";
   mnemonic = "E";
   list = "Zentimeter";
   edit_width = 12;
   width = 12;
 ok_only;
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 9 of 9
john.uhden
My popup_lists in 2002 show a white background.  Of course when you select one the background turns blue.
John F. Uhden
