DCL help needed
DCL help needed
My_Civil_3D
DCL help needed
My_Civil_3D
Hi guys i am creating buttons that will insert blocks. But for some reason the dcl keeps on leaving a space in between buttons, how can i avoid this:
picture_dcl1
:dialog
{label = "DRA STANDARDS";
:row
	:boxed_column
	label = "ARROWS";
	:button{key = "BtnNorth";label = "NORTH ARROW";value = "0";}
	:button{key = "BtnFallSlope";label = "FALL / SLOPE";value = "0";}
	:button{key = "BtnFlowDirection";label = "FLOW DIRECTION";value = "0";}
	:button{key = "BtnDirection";label = "DIRECTION ARROW";value = "0";}
	:button{key = "BtnLevelArrow";label = "LEVEL ARROW";value = "0";}
	:boxed_column
	label = "HEADERS";
	:button{key = "LayoutHeader";label = "LAYOUT HEADER"; value = "0";}
	:button{key = "SectionHeader";label = "SECTION / DETAIL HEADER"; value = "0";}
ok_only;
Civil 3D Certified Professional
paullimapa
add these for row:
picture_dcl1 : dialog {
    : row {
        children_alignment = top;
        children_fixed_height = true;
Paul Li
IT Specialist
@The Office
My_Civil_3D
thank you sir this worked perfectly, i have been looking around to find more detailed guides and info regarding the dcl in general i cant find any real info, do you perhaps know where i can find more study material regarding dcl?
paullimapa
You are very welcome
For me learning dcl is just lots of trials and error. So experience is gained by just doing it and of course looking at existing dcl to see how others have done it. But you probably know of the famous afar lisp site that gives a great start on learning dcl
https://www.afralisp.net/archive/index.htm
Then there are others online as well like
https://autolisp-exchange.com/Tutorials/MyDialogs.htm
Doing a search online for “autolisp dcl reference” would also get good results
Paul Li
IT Specialist
@The Office
Sea-Haven
My $0.05 old fashioned menu.
paullimapa
I also still use the menu method for hatch pattern selections categorized by various materials:
Paul Li
IT Specialist
@The Office
Sea-Haven
Yep if you can use notepad you can make a choose menu no real programming skill required.
