DCL action_tile with slide more defined
dennis
Advisor Advisor
dennis
I have noticed that when I have slides defined via action_tile in a DCL dialog, if I press-hold on the image, it becomes bright.  Then after letting go of the pick, then the image has a barely discernible dashed-line around it.  Is there a way to get it to hold the 'brighter look'?  Would be nicer for the user to know which is picked.
lando7189
The 'brigher' look is actually a 'negavite' of the slide (reversed color values) that happens when it is clicked.  I don't believe there is a way to make the tile show reversed values permanently.  - Lanny
scot-65
Some possible options:
Create a second set of slides that has a different background.
If, for instance, your slides have a black background, use a gray background.
Action tile to switch out all slides.
Another method is to place a text_part "header" inside the dialog and associate
text for the selected tile to show in this header.
:text_part {key="Tex001"; alignment=centered;}
(action_tile "Img101" "(set_tile \"Tex001\" \"Image 101 selected.\")")
I once used image tiles as colored buttons that behave like radio buttons. Next to these
colored buttons is an edit box. When a colored button is selected, the mode tile of the
edit box is 0 and all others are set to 1.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
paullimapa
In addition to what other posters have replied, you can also specify a different color background to the image tile as explained here:
http://www.afralisp.net/archive/lispa/lisp49q.htm
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
dennis
I was in hopes that I could use the toggle for mode_tile = 4, but I don't see a way to test the existing setting on the tile to know whether to "toggle or not to toggle".  Seems scot-65 your two options is it.
By the way, I did pursue the background color but found that can only be set in the DCL file.  Correct me if I am wrong.
An alternative I found too in searching the threads, was to write a DCL on the fly .... but I honestly do not want to work that hard.
scot-65
Well, I was suggesting 2 sets if images - one with a light background and one dark.
I have not worked with images in a DCL to help you further here other than it can
"flip" with the start_image / end_image functions. Program structure will be similar
to the function example I show below.
For mode_tile = 4, a little work is required, but it is possible. Again, limited
knowledge with images...
In your action tile section make a call to a newly created function for all the
defined image tiles and send an argument which is the tile's "key":
 (action_tile "Img101" "(IMG_MODE \"Img101\")")
 (action_tile "Img102" "(IMG_MODE \"Img102\")")
If there are other (existing) calls inside the image's action tile, squeeze the function
inside the quotes as well. Example:
 (action_tile "Img101" "(done_dialog 1)") becomes
 (action_tile "Img101" "(IMG_MODE \"Img101\")(done_dialog 1)")
Now for the function that accepts one argument:
(defun IMG_MODE ( a / )
 (foreach x (list "Img101" "Img102" "Img103" "Img104") ;etc.
  (mode_tile x (if (= a x) 4 0))
 );foreach
);end IMG_MODE
Scot-65
