Data Extraction via lisp
lee.pellegrin
lee.pellegrin
Is there any way to use lisp in acad LT to do data extraction in a file in order to populate a table?
paullimapa
Share in detail exactly what you want to extract from Lt dwg
Attach a sample dwg and a sample csv
Paul Li
IT Specialist
@The Office
Sea-Haven
Please also clarify do you want an Autocad "Table" or want to export to Excel via a csv. If you want a "Table" then make sure sample dwg has exactly what you want as a sample table. Most to a "Table" involves a custom answer, so be patient.
Did you look at "Dataextraction" ? I believe it's in LT.
paullimapa
No Dataextraction command in LT
Paul Li
IT Specialist
@The Office
Sea-Haven
@paullimapa thanks for that info.
Yes its in Bricscad plus more.
