Cycle thru all blocks - Explode nested blocks (lisp)
jlaidle1
jlaidle1
I need a LISP that will cycle thru all blocks in the drawing, then explode any nested blocks within it.
Anyone have this, or an example on how to cycle thru blocks?
John Laidler
ITO - Application Management
Please use "Accept as Solution" & give "Kudos" if this response helped you.
jlaidle1
I found this code from another post.
(defun c:explodenested (/ test)
(vlax-for blk (vla-get-blocks (vla-get-activedocument
(vlax-get-acad-object)))
(if (and (eq (vla-get-isxref blk) :vlax-false)
(eq (vla-get-islayout blk) :vlax-false)
(vlax-for ent blk
(if (eq (vla-get-objectname ent) "AcDbBlockReference")
(progn
(setq test (vl-catch-all-apply
'(lambda ()
(vlax-invoke ent 'explode)
(if (not (vl-catch-all-error-p test))
(vla-delete ent)
(princ)
John Laidler
dbhunia
Hi
As your requirement.....
You can try this........
(This is a little modified code of "lee-mac", for more check this.... http://lee-mac.com/upgradedburst.html)
(defun c:nburst ( / *error* sel )
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
        (princ)
    (LM:startundo (LM:acdoc))
    (if
        (setq sel
            (LM:ssget;;; "\nSelect block to burst: "
		(list "_X"
                    (cons '(0 . "INSERT")
                            (lambda ( / def lst )
                                (while (setq def (tblnext "block" (null def)))
                                    (if (= 4 (logand 4 (cdr (assoc 70 def))))
                                        (setq lst (vl-list* "," (cdr (assoc 2 def)) lst))
                                (if lst (list '(-4 . "<NOT") (cons 2 (apply 'strcat (cdr lst))) '(-4 . "NOT>")))
        (repeat (setq idx (sslength sel))
            (LM:burstnested (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
    (princ)
(defun LM:burstnested ( obj / col idx lay lin lst obj )
    (if (and (= "AcDbBlockReference" (vla-get-objectname obj))
             (vlax-write-enabled-p obj)
             (not (vl-catch-all-error-p (setq lst (vl-catch-all-apply 'vlax-invoke (list obj 'explode)))))
        (progn
            (setq lay (vla-get-layer obj)
                  col (vla-get-color obj)
                  lin (vla-get-linetype obj)
            (foreach att (vlax-invoke obj 'getattributes)
                (if (vlax-write-enabled-p att)
                    (progn
                        (if (= "0" (vla-get-layer att))
                            (vla-put-layer att lay)
                        (if (= acbyblock (vla-get-color att))
                            (vla-put-color att col)
                        (if (= "byblock" (strcase (vla-get-linetype att) t))
                            (vla-put-linetype att lin)
                (if (= :vlax-false (vla-get-invisible att))
                    (   (if (and (vlax-property-available-p att 'mtextattribute) (= :vlax-true (vla-get-mtextattribute att)))
                            LM:burst:matt2mtext
                            LM:burst:att2text
                        (entget (vlax-vla-object->ename att))
            (foreach new lst
                (if (vlax-write-enabled-p new)
                    (if (= "AcDbAttributeDefinition" (vla-get-objectname new))
                        (vla-delete new)
                        (progn
                            (if (= "0" (vla-get-layer new))
                                (vla-put-layer new lay)
                            (if (= acbyblock (vla-get-color new))
                                (vla-put-color new col)
                            (if (= "byblock" (strcase (vla-get-linetype new) t))
                                (vla-put-linetype new lin)
                            (LM:burstnested new)
            (vla-delete obj)
    (princ)
(defun LM:burst:removepairs ( itm lst )
    (vl-remove-if '(lambda ( x ) (member (car x) itm)) lst)
(defun LM:burst:remove1stpairs ( itm lst )
    (vl-remove-if '(lambda ( x ) (if (member (car x) itm) (progn (setq itm (vl-remove (car x) itm)) t))) lst)
(defun LM:burst:att2text ( enx )
    (entmakex
        (append '((0 . "TEXT"))
            (LM:burst:removepairs '(000 002 070 074 100 280)
                (subst (cons 73 (cdr (assoc 74 enx))) (assoc 74 enx) enx)
(defun LM:burst:matt2mtext ( enx )
    (entmakex
        (append '((0 . "MTEXT") (100 . "AcDbEntity") (100 . "AcDbMText"))
            (LM:burst:remove1stpairs  '(001 007 010 011 040 041 050 071 072 073 210)
                (LM:burst:removepairs '(000 002 042 043 051 070 074 100 101 102 280 330 360) enx)
(defun LM:ssget (arg / sel msg)
    ;(princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget arg))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com) (princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
