Customized move tool
Hello once again,
From time to time I need to move twice in a row the same object in ortogonal fashion:
- in example: 100 units left and then 50 unit up
- or: 50 units right and 20 units down etc.
I wrote this code that (almost) work...
It moves object up&right or up&left.
It swapped moving down&left with down&right and vice versa...
(defun c:magic_move (/ selection dist dist2 base quadrant move1 move2)
  	(setq selection (ssget))
	(setq dist (getreal "\nMagic move: "))
  	(setq dist2 (getreal "\nMagic move: "))
  	(setq base (getpoint "\nBase point: "))
  	(setq quadrant (getpoint base))
	(if (> (car quadrant) (car base))
	  	(if (> (cadr quadrant) (cadr base))
			(setq 	move1 	(polar base 0 dist)			;right
				move2	(polar base (/ pi 2) dist2)		;up
	  	(if (< (cadr quadrant) (cadr base))
				move2	(polar base (* 1.5 pi) dist2)		;down
	(if (< (car quadrant) (car base))
		  	(setq 	move1 	(polar base pi dist)			;left
(magic_move move1 move2)
); defun
(defun magic_move (move1 move2)
  	(command "move" selection "" base move1 "")
  	(command "move" selection "" base move2 "")
  	(princ)
); defun
Anyone sees this bug?
dlanorh
Have a look at this topic. https://www.theswamp.org/index.php?topic=55529.0
I am not one of the robots you're looking for
doaiena
Just point to a direction with the mouse and write the number of units you want to move with.
(defun c:test ( / ss basePt p1 p2)
(if (setq ss (ssget))
(progn
(while (not basePt) (setq basePt (getpoint "\nPick base point: ")))
(while (not p1) (setq p1 (getpoint basePt "\nPick next point or enter distance: ")))
(while (not p2) (setq p2 (getpoint p1 "\nPick last point or enter distance: ")))
(command "move" ss "" basePt p2)
(princ)
);defun
PS: Just had another idea. Infinite moves, until you end the command.
(defun c:test ( / ss basePt flag p1)
(progn
(setq flag T)
(while flag
(if (setq p1 (getpoint basePt "\nPick next point or enter distance: "))
(progn
(command "move" ss "" basePt p1)
(setq basePt p1 p1 nil)
(setq flag nil)
(princ "\nDone!")
(princ)
);defun
hak_vz
@Anonymous wrote:
Hello once again,
Ok. the only tricky point is when you dont know horizontal and vertical displacent. We all know that any transition has its on horizontla and vertical part, ortogonality is there . If you have to make ortogonal transitions in rotated coordinated system change it.  Moving objects using "@" relative coordinate is easy. Polar tracking too.
This equals move @dist1,dist2
I wont answer your task by writing some new code , but will show here my helper functions to store variable, distance, selection set or a point into a named global variables, and also helper to review and clear globals (saved in a list). I've added a function rm to perform relative move. Maybe you find it usefull.
(setq globals nil)
(defun c:globals () globals)
(defun twodec (x)(atof(rtos x 2 2)))
(defun c:clear ()
	;clears all global variable generated by our macros
	(while (and globals) (set (read (car globals)) nil) (setq globals (cdr globals)))
	(if (not globals) (alert "Autolisp globals have been cleared!"))
	(princ)
(defun odefined (p / defined i)
	(setq defined nil i 0)
	(if globals
		(repeat (length globals)
			(if (= p (nth i globals))(setq defined T))
		(setq i (+ i 1))
	defined
(defun c:gd (/ pp _name)
;get distance and assign to variable name
	(setq pp (atof(rtos(distance (getpoint "\nSelect first point > ")(getpoint "\nSelect second point > ")) 2 5)))
	(setq _name (getstring "\n Naziv variable > "))
    (set (read _name) pp)
	(princ)
	(setq globals (cons _name globals))
	(strcat _name " = " (rtos pp 2 5))
(defun c:gp ( / pp _name)
;get point and assign to variable name
	(setq pp (mapcar 'twodec (getpoint "\nSelect point > "))
		_name (getstring "\n Variable name > "))
	pp
(defun c:sv( / pp _name)
	;assign value to variable name
	(setq pp (getreal "\n Enter value >"))
	(setq _name (getstring "\n Variable name > "))
(defun c:ss( / pp _name)
	;assign name to some selection set
	(setq pp (ssget))
(defun c:rm (/ hor ver ss)
(setq hor (getreal "\nHorizontal distance >")
	  ver (getreal "\nvertical distance >")
	  ss (ssget)
(command "move" ss "" (list 0 0) (strcat "@" (rtos hor 2 5) "," (rtos ver 2 5 ) ""))
(princ)
To function rm you may answer with stored variables for some measured distance. If you named your variable "a" then you recall it with as "!a".  Or any number you like.
Or you may store object to named selection set (let say a) with comand ss and move it with command move and polar tracking. Sorry, don't see a need for special code to do that.
Miljenko Hatlak
hak_vz
If you need to move previous object repeatedly you may use acads "move" command option previous.
Command: m
Select entities to move: p
That way you avoid continuous reselection of same object(s). At first iteration you may answer with the name of your previously defined selection set name you stored into a global variable. With polar tracking or ortho on you just select previous entity(es), click wherever, move a mouse to desired direction and type a distance.
Miljenko Hatlak
@doaiena @hak_vz @dlanorh
Thank you for your ideas. Nevertheless, I found myself the bug in my code... after "if statements" there was missing "progn". I guess my initial code didn't evalute the "inner if statements" properly...
	(progn
	(progn
); defun
  	(princ)
); defun
Now it's working!
Sea-Haven
Much simpler wrote 2 defuns Chx Chy as the name implies asks for distance + / - then pick objects.
(defun C:CHX ()
  (SETVAR "CMDECHO" 0)
  (setq sn (getvar "osmode"))
  (command "osnap" "near")
  (setq x 0)
  (princ "\nalters object in X direction")
  (setq ht (getstring "\n What is amount of change: "))
  (setq newht (strcat ht ",0"))
  (while (= x 0)
    (setq newobj (entsel "\nPoint to object: "))
    (if (/= newobj nil)
    (progn
    (command "move" newobj "" "0,0" newht)
  (if (= newobj nil)(setq x 1))
(defun C:CHY ()
  (setq x 0)
  (princ "alters object in Y direction")
  (setq newht (strcat  "0," ht))
  (while (= x 0)
  (SETQ NEWobj (entsel "\nPoint to object: "))
  (if (/= newobj nil)
  (progn
;simple routine to change objects in the z direction
(defun C:CHZ ()
  (setq x 0)
  (princ "alters object in Z direction")
  (setq newht (strcat "0,0," ht))
  (while (= x 0)
  (if (/= newobj nil)
  (progn
  (command "move" newobj "" "0,0,0" newht)
