Custom Rev Cloud
Custom Rev Cloud
joe_kohli
Custom Rev Cloud
joe_kohli
I use a tremendous amount of rev clouds in my drawings I do for work. I have several different layers that they all fall under. I am trying to simplify and make the process much easier and quicker. Here is how I use my rev clouds when I am making a change to a drawing:
If it is just a simple cloud (square or circular) then I do this:
Select RevCloud icon
Resize the ARC to 0.1875
Change the width to 0.02
Change the layer to "Piping"  (or whatever other layer I choose)
If it is just a complex cloud (with many bends and twist) then I do this:
Draw a polyline around the area
Convert polyine to revcloud
Change the ARC to 0.1875
Is there a way to make this a preset so I can place it into a Tool Palette. For example, from the tool palette, I would select it and it would draw a RevCloud in the layer and settings I showed above and it would draw it just like a polyline draws out? I want it to act like a linetype so that I can just drag and drop from the TP and start drawing but it would be all in "Revcloud" format.
I would even be ok designing a new line type that basically mimics a Revcloud, however, I do need it to act like a polyline where it would be one entity (so I can quickly select the whole cloud and edit or delete it).
VincentSheehan
You could create a lisp then create a Tool Palette button to load the lisp.
(defun c:rvcl (/ )
(command "-layer" "set" "PIPING" "")
(command "revcloud" "a" "0.1875" "0.1875" "o" pause)
(command "no")
(command "_LayerP")
(command "pedit" "last" "width" "0.02" "")
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
joe_kohli
Where would you place the lisp file? I tried to replace the macro line in the "freehand" revcloud button with this format:
^c^c^p (load "mypath\mylispprogram")
But it did not work. I just need some guidance on how I would achieve this to make it work.
Kent1Cooper
Inside Autolisp functions, use either a double backslash or a forward slash as a file path separator.
Kent Cooper, AIA
