Custom "DIM" commands
info
Message 1 of 8
info
I want to create a custom command by duplicating the “DIM” command that will give me the “Ordinate” command option and turn on ORTHO. I am having trouble with the exact syntax. Can anyone offer some help?
Replies (7)
Message 2 of 8
Kent1Cooper
What have you tried so far?  It sounds like an easy enough command to define, but checking for corrections to something you've started could be easier than starting from scratch.
Kent Cooper, AIA
Message 3 of 8
info
My first thought was this... ^C^Cortho on _dim o;
I used this same method with other commands that had command line option and it worked, for instance:
When I wanted a vertical construction line I did this: ^C^C_xline v;  and it works but the "dim" command it does not.
Message 4 of 8
devitg
@info  tear off the space o ;
^C^Cortho on _dim
Message 5 of 8
info
There is no space after the "o" now.
Or are saying to add one, so I did : ^C^Cortho on _dim o ;
This isn't working either. Here are the results:
Command: ortho Enter mode [ON/OFF] <ON>: on
Command: _dim
Dim: o O
Dim:
** That command may not be invoked transparently **
Message 6 of 8
devitg
@info Please test as follow
^C^C"orthomode"1 _dim o
Message 7 of 8
info
Here are the results of that...
Command: "orthomode"1 Unknown command ""ORTHOMODE"1". Press F1 for help.
Command: _dim
Dim: o O
Dim:
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Dim:
Message 8 of 8
Kent1Cooper
For most of my AutoCAD years, DIM was not a command, but was added late in the game with the different kinds as options.  I don't know whether there's something peculiar about using DIM in a macro, but the direct DIMORDINATE command works for me:
^C^Cortho on _dimordinate
[And don't put a ; at the end -- Enter is assumed as a conclusion unless a macro's contents end with a control character such as ^P for echoing to the command line.  My first suggestion was going to be to remove the ; from the end of yours, but that doesn't work either.]
Kent Cooper, AIA
