CUSTOM PULL DOWN MENU FOR BLOCK LIBRARY
AutoCad 2012
First off, I'm not accustomed to programming in AutoCad. I have been having my block library folder open right next to AutoCad so I can just drag and drop .dwgs into the drawing I'm working on.
1) How do I create a pull down menu that can pull blocks from my block library? Or, what is a good document to show me how?
2) Is it possible to make the pulldown sub-menu follow the filepaths without having to program in every single sub-filepath?
- I have already looked into making pallets. This is not what I am looking for.
3) Is there a way to make it so that when you do bring in a block, it doesn't ask you what x,y scale and angle you want it to be?
Jonathan3891
Read this for creating a pulldown menu.
The command will be one of the following...
If you have a support path set to your block folder;
^C^C-insert;Block.dwg;Scale;1;0,0,0;0;
If you dont, then use;
^C^Cinsert;PATH AND NAME OF BLOCK;1;0,0,0;0;
I personally like to place all my block on a tool palette. You can drag and drop them too the palette, then right click and select properties. There you can set how you want the block to come in.
Jonathan Norton
Blog | Linkedin
pendean
Community Legend
Community Legend
Any reason you want to avoid using ADCENTER or TOOLPALETTEs for this simple task? Never take any more clicks hat hunting/clicking a pulldown menu.
I DON'T REALLY CARE FOR THE TOOL PALLET BECAUSE I JUST HAVE WAY TO MANY BLOCKS TO SORT THROUGH.
The ADCENTER makes me type in a scale for x,y and an angle for putting in the block. I'd like to have it where I can just drag and drop it in the drawing without having to do the inputs. Like if the inputs for the scale where just automatically set to 1,1,0=x,y,angle.
