Custom macro - select all text
Message 1 of 17
Is it possible to write a macro that will select all the text objects in a drawing?
I know QSELECT will do this rather quickly & easily, but I'm trying to create a one-click button in a toolbar that will do this.
Possible? Impossible?
Replies (16)
Message 2 of 17
Shneuph
Try making a toolbar button command and put this as the macro:
(if (= (getvar "cmdactive") 1) (ssget "x" '((0 . "*TEXT*"))) (sssetfirst nil (ssget "x" '((0 . "*TEXT*")))))
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 3 of 17
Nice, that did it!
Thanks!!
Message 4 of 17
Philip-John
Currently it selects all texts in the drawing.
Is it possible to work this lisp within a selection?
Message 5 of 17
cadffm
[F1] ssget
Remove the "x"
X
Entire database. If you specify the X selection method and do not provide a filter-list, ssget selects all entities in the database, including entities on layers that are off, frozen, and out of the visible screen.
Sebastian
Message 6 of 17
Philip-John
Message 7 of 17
Sea-Haven
If you imply the ssget as a variable you can use it directly (setq ss (ssget (list (cons 0 "*Text*))))
Like move !ss <enter>
Copy !ss <enter>
Note the !
Another trick is to make a defun of the ssget then you can use a transparent selection copy 'ss <enter> note the defun is c:ss and transparent is ' not exclamation mark.
I think it was over at cadtutor did 4 different filters text pline lines circle etc. can just be used in a normal command 'sst wastext, 'ssl was lines.
Message 8 of 17
I tried to make a macro selecting all the TEXT in continuous but it does not work: / do you know how to help me?
^ C ^ C (sssetfirst nil (ssget "_X" list '(0. "TEXT")' (-4. "! =") '(6. "CONTINUOUS")))
Message 9 of 17
dlanorh
The highlighted (red) text states NOT equal, try changing to "=" or "&="
I am not one of the robots you're looking for
Message 10 of 17
Even with this change nothing is done
Message 11 of 17
cadffm
useful or not, take what you asked for
^C^C(sssetfirst nil (ssget "_X" '((0 . "TEXT")(6 . "CONTINUOUS"))))
Sebastian
Message 12 of 17
Thank you, I did not understand my mistake.
Et si je veux simplement prendre les textes qui ne sont pas en CONTINUOUS ?
Message 13 of 17
dlanorh
(6. "CONTINUOUS") should be (6 . "CONTINUOUS) space between 6 and "." otherwise it is may not be recognised.
Message 14 of 17
cadffm
@dlanorh you answered to me!? (you replied to my answer), but i already posted the whole working line above.
And 6 . instead 6. ist not the only one mistake.
Spaces between ^ C
Space in front of the first bracket
missing brackets for LIST function
(0. instead (0 .
(6. instead (6 .
(-4. "! =") instead (-4 . "<not")(6 . "Continuous")(-4 . "not>") // or just (6. "~CONTINUOUS")
But he asked for the opposite, so skipped all
Sebastian
Message 15 of 17
dlanorh
Sorry,I'm in a bit of a zombie state at the moment. I really need to get some sleep.
Message 16 of 17
cadffm
Sebastian
Message 17 of 17
Kent1Cooper
@cadffm wrote:
.... (-4 . "<not")(6 . "Continuous")(-4 . "not>") // or just (6. "~CONTINUOUS")
Bear in mind that such an approach will also "find" things that are of Continuous linetype simply because their linetype is ByLayer and their Layer's linetype is Continuous.  It will omit  only Continuous-linetype things that are that way because they have Continuous linetype assigned as a property override.
Kent Cooper, AIA
