Custom Buttons
Custom Buttons
twedgewood28
Custom Buttons
twedgewood28
Community Visitor
Community Visitor
I have some drafting tickets that I need to create custom buttons for.  I am new to learning LISP.  I need buttons for the following attributes:
Length
Thickness
Height
Cube / Total Cube (Based off quantity x Cube)  Maybe one button to calculate both??
Like I said I am new to this just needing some assistance.
See attached ticket file.
MrJSmith
Are you creating a DCL? Or are you creating buttons on the ACAD ribbon? This has everything you need to know to create a DCL: https://www.afralisp.net/dialog-control-language/
twedgewood28
Community Visitor
Community Visitor
Trying to create a button on the AutoCad Ribbon.
paullimapa
Many can be found on-line by just doing a simple search to customize the ribbon:
By adding a new panel:
https://www.youtube.com/watch?v=fW0WqLp6czo
To add a button:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-add-a-butto...
More cutomizations:
https://www.synergis.com/2017/06/08/tip-customizing-the-autocad-ribbon/
Adding Partial menus:
https://www.youtube.com/watch?v=5mtpNkfkTi0
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
To be clear, you want to create buttons in the Ribbon that can replace each of these with some number from some source to be determined automatically, yes?
And at these locations, one entry is in inches and the adjacent is a conversion to... mm? cm? not related to the inches?
Were are these LISPs-inside-the-buttons getting the information from please? Will the user type a response to each prompt? Or...?
Sea-Haven
For me use this program it is a library program that asks the questions you want, its like 3 lines of code that is all.
You must save it in a support path so it can be autoloaded.
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Enter values " "Length " 5 4 "6" "thickness " 5 4 "1" "Height " 5 4 "6" )))
(setq Len (atof (nth 0 ans))
    Thick (atof (nth 1 ans))
    Ht (atof (nth 2 ans))
Part 2 is update your block attributes.
As I said make your ticket a block with attributes Length, Thickness, Height, Cube, Totcubes.
Oh yeah what are you drawing is it cubes that can be done also.
