CUIX file from the scratch
miroC8S4H
miroC8S4H
Dear ADN members,
I am about to create CUIX file from the scratch, for classic style, using toolbars and menus. Unfortunately, I can’t make the menus to be shown!
Precisely, I am creating these files: “Header.cui”, “MenuGroup.cui”, “PopMenuRoot.cui”, “ToolbarRoot.cui”, “Menu_Package_Info.xml”, “[Content_Types].xml” and packing them with images of PNG file type.
Using “CUILOAD”, MenuGroup is visible, toolbars are loaded with images and linked to Macros.
But menus are not shown, even they are visible in Workspace! I am using AutoCAD 2020.
I would appreciate any help how to solve this.
Thanks in advance and best regards, Miro M.
miroC8S4H
Let me reply to my own topic, because I found the solution.
It’s easy, straightforward and it is implemented inside of NET API – CustomizationSection !
Once CustomizationSection is created, you can add macros, menus, icons, tollbars and save it into CUIX file, which is highly compatible through AutoCAD versions.
