CUI Double Click tree has yellow ! marks
Scottu2
Scottu2
When I use the CUI to edit the Double Click Actions, the icon has a yellow exclamation mark next to them.
What does the yellow "!" marks mean on the tree icon?
How do I fix it?
Thanks.
paullimapa
Seems like another poster back in 2010 had a similar problem but there were no answers:
http://forums.autodesk.com/t5/autocad-2010-2011-2012/doubleclick-action-problem/td-p/2680634
Have you tried another computer to see if that problem occurs?
If the problem only occurs on that single computer, perhaps the menu is corrupted and will require recompiling?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
Hi -
One clue, is that the double-click action with a yellow exclamation MIGHT mean that the double-click action is being overridden by another loaded .cuix menu file.
Do you have other custom or partial menu files that have double-click actions defined in them?
 Hope that helps....
 -MRG
Scottu2
Muddyrunnergirl,
I opened the CUI and right-clicked on the ACAD menu and tried the restore cuix - did not work.
then i tried the Reset cuix and it work!   🙂  Great
I did however some minor fixes where required: other menus need to be reloaded and the profile redefined.
Thanks for the help guys,
Scott
Seychellian
@Scottu2 wrote:
Muddyrunnergirl,
This worked for me.... THANKS dude!
While im here.... Does anyone know how to bypass the additional dialogue box that you get after double clicking where you need to select the block name (it is a redundant step given that you have double-clicked the block that you intent to open). On the Mac version I have been using it does not have this step.
Thanks!
ВeekeeCZ
Add - prior to bedit in cui/2click/block macro.
-bedit
Seychellian
-bedit
Hey thanks... but where exactly (see attached)
