CSV file import into AutoCAD
prajputZ23VK
prajputZ23VK
Hello Everyone,
I have a CSV file which contains two columns with 10000 rows, when I tried importing using OLE Object and Data Link, both are very slow and lot of steps involved like import, resizing the table, etc.
Is there any way I can import it using command (avoid using GUI) and import the data? Like any easy way.
Even I am planning to split my CSV data into smaller size, so that I can import it easily.
PR
Sea-Haven
If happy to use a csv file just google that "CSV to Table lisp". I have something but need to edit.
1 question is 1st line a description of what is in the desired table. As a 1st go the default table style will be used. This can be changed a selected tablestyle or redo the table properties.
Post a like 10 line excel.
