Crossing Angle
Crossing Angle
bit_Cad2018
Message 1 of 30
Crossing Angle
bit_Cad2018
All masters.
                    I want the angle at every intersection points of polyline
please find the sample drawing
Replies (29)
Message 2 of 30
hak_vz
Please upload more complex sample to save yourself from answering to many questions.
Miljenko Hatlak
Message 3 of 30
hak_vz
Before you update some more applicable sample here is a major part of code you are looking for.  Following code creates a list as follows. If there is some good soul, he will create update to my function that populates a table object from data received in a list. If not, you will have to wait till I have time to finish it
((117.075 "135" "0") (198.065 "75" "ASP ROAD") (235.485 "102" "0") (302.381 "75" "Canal") (421.4 "48" "0") (540.234 "78" "0"))
So here is the code. It is made with presumption that all crossing elements are non elevated lwpolylines. In some situation you may have to reverse polyline if distances don't match. It works correct on a sample you've provided.
(defun c:pia ( / sort keyValue rad_to_deg deg_to_rad vector vect_dot vect_mod create_value_vector unit_vect asin acos vectorSide lwpolysections
                 cdist pipeline ss_cross npoints ent i pts e seg ip di v1 v2 e ang ret *error*)
    (vl-load-com)
    (defun *error* () (princ))
    (defun sort (lst) (vl-sort lst '(lambda (p1 p2)(< (car p1)(car p2)))))
    (defun keyValue (key el)(cdr (assoc key el)))
    (defun rad_to_deg (rad)(* 180.0 (/ rad PI)))
    (defun deg_to_rad (deg)(* PI (/ deg 180.0)))
    (defun vector (p1 p2) (mapcar '- p2 p1))
    (defun vect_dot (v1 v2)(apply '+ (mapcar '* v1 v2)))
    (defun v+ (v1 v2)(mapcar '+ v1 v2))
    (defun v- (v1 v2)(mapcar '- v1 v2))
    (defun vect_mod (v)(sqrt(vect_dot v v)))
    (defun create_value_vector (n val / r ) (repeat n (setq r (cons val r))) r)
    (defun unit_vect (v)(mapcar '* v (create_value_vector (length v) (/ 1 (vect_mod v)))))
    (defun asin (x)
      (cond
        ((and(> x -1.0)(< x 1.0)) (atan (/ x (sqrt (- 1.0 (* x x))))))
        ((= x -1.0) (* -1.0 (/ pi 2)))
        ((= x  1) (/ pi 2))
    (defun acos (x)(cond ((and(>= x -1.0)(<= x 1.0)) (-(* pi 0.5) (asin x)))))
    (defun vectorSide (v1 v2 p / r *fuzz*)
        (setq r (- (* (-(car v2)(car v1))(-(cadr p)(cadr v1)))
                   (* (-(cadr v2)(cadr v1))(-(car p)(car v1)))
            *fuzz* 1e-10
        (cond ((equal r 0.0 *fuzz*) 0) (t (fix (/ (abs r) r))))
    (defun lwpolysections(e start end / ent npoints elev pts pset p1 p2 i v1 v2);
        (setq ent (entget e) pts (list))
        (if (and ent)
            (progn
                (setq npoints (keyValue 90 ent) npoints (fix npoints) elev (keyValue 38 ent) i 0)
                (repeat (length ent)(setq pp (nth i ent))(if (eq (car pp) 10) (setq pts (append pts (list (cdr pp))))) (setq i (+ i 1)))
                (if (eq (keyValue 70 ent) 1)
                    (setq pts (cdr (reverse pts)) pts (reverse pts) npoints (- npoints 1)) ; closed lwpoly
                (setq i 0)
                (repeat (- npoints 1)
                    (setq p1 (nth i pts) p2(nth (+ i 1) pts))
                    (if (and v2) (setq v1 v2 v2 (vectorSide start end p2))(setq v1 (vectorSide start end p1) v2 (vectorSide start end p2)))
                    (if (not (eq v1 v2))(setq pset(append pset (list(list p1 p2 (cdr (assoc 8 ent )))))))
                    (setq i (+ i 1))
       pset
    (setq cdist 0 i 0)
    (setq pipeline (car(entsel "\nSelect pipeline >")) ent (entget pipeline))
    (setq ss_cross (ssget "x" (list '(0 . "lwpolyline") '(-4 . "<not")'(8 .  "Proposed Pipeline") '(-4 . "not>"))))
    (repeat (length ent)(setq pp (nth i ent))(if (= (car pp) 10) (setq pts (cons (cdr pp) pts))) (setq i (+ i 1)))
    (setq pts (reverse pts) i 0 j 0)
    (repeat (- (length pts) 1)
        (setq start (nth i pts) end (nth (+ i 1) pts))
            (setq ss_cross (ssget "F" (list start end) (list '(0 . "lwpolyline") '(-4 . "<not")'(8 .  "Proposed Pipeline") '(-4 . "not>"))))
            (if ss_cross
                (progn
                        (repeat (sslength ss_cross)
                            (setq int_segs (lwpolysections (ssname ss_cross j) start end))
                               (foreach e int_segs
                                    (setq e (car int_segs) int_segs (cdr int_segs))
                                    (setq p1 (car e) p2 (cadr e) name (last e))
                                    (setq ip (inters start end p1 p2 T))
                                    (setq di (+ (distance start ip) cdist))
                                    (setq v1 (vector ip start) v2 (vector ip p2))
                                    (setq ang (rtos (rad_to_deg(acos (/ (vect_dot v1 v2) (* ( vect_mod v1)(vect_mod v2))))) 2 0))
                                    (setq ret (cons (list di ang name) ret))
                                (setq j (+ j 1))
                    (if (< i (- (length pts) 1)) (setq cdist (+ cdist (distance start end))))
       (setq i (+ i 1) j 0 )
    (setq ret (sort ret))
Miljenko Hatlak
Message 4 of 30
Sea-Haven
There is another post at Cadtutor and asks for chainage of point also.
Re "maybe reverse pline" the 1st question should be pick start end so straight away know which end is Ch 0.0
I did not see the create table in code. (hint Cadtutor)
Message 5 of 30
bit_Cad2018
Its what you gave me. He useful for me
If you have some time, then if you give an option to export to Excel or text file, it would be better
Thanks hak_vz. may god bless you
Message 6 of 30
hak_vz
I didn't have a time to do all this stuff but will do it today if possible. But just with this code he can do all the rest.
Miljenko Hatlak
Message 7 of 30
hak_vz
Here is final code that enables you to create acad table, write to txt file, or both.
                 cdist pipeline ss_cross npoints ent i pts e a seg ip di v1 v2 e ang  ret *error* table row *acdoc*)
    (vl-load-com)
    (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object))))
    (defun sort (lst) (vl-sort lst '(lambda (p1 p2)(< (cadr p1)(cadr p2)))))
    (defun asin (x)
      (cond
        ((= x  1) (/ pi 2))
            *fuzz* 1e-10
        (if (and ent)
            (progn
                (setq i 0)
                    (setq i (+ i 1))
       pset
    (setq cdist 0 i 0)
            (if ss_cross
                (progn
                               (foreach e int_segs
                                    (setq ret (cons (list name di ang ) ret))
                                (setq j (+ j 1))
    (setq ret (sort ret) i 0)
   (initget 1 "yes no")
   (if (= (getkword "\nWrite to acad table? (yes no) >") "yes")
       (progn
       (setq table (vla-addtable
                (vla-get-modelspace *acdoc*)
                (vlax-3d-point (getpoint "\nSelect table insertion point >"))
                (+ 2 (length ret))
                    4			; number of colums
                    5			; cell height
                    30			; row width
              (vla-put-TitleSuppressed table :vlax-false)
              (vla-put-HeaderSuppressed table :vlax-false)
              (vla-setcelltextheight table 0 0 2.5)
              (vla-setText table 0 0 "LIST OF ALL CROSSINGS FALLING ON THE ROUTE OF THE PIPELINE")
              (repeat 4 (vla-setcelltextheight table 1 i 1.8) (setq i (1+ i)))
              (vla-setText table 1 0 "Number")
              (vla-setText table 1 1 "Type of crossing")
              (vla-setText table 1 2 "Chainage (m)")
              (vla-setText table 1 3 "Angle of crossing")
          (setq row 2 i 0)
          (foreach item ret
                (repeat 4 (vla-setcelltextheight table row i 1.8) (vla-setCellAlignment table row i 5) (setq i (1+ i)))
                (vla-settext table row 0 (- row 1))
                (vla-settext table row 1 (car item))
                (vla-settext table row 2 (rtos(cadr item) 2 2))
                (vla-settext table row 3 (last item))
                (setq row (1+ row) i 0)
      (if (= (getkword "\nWrite to file? (yes no) >") "yes")
      (progn
          (setq f (getfiled "Exit file to write chainage:" (getvar "dwgprefix") "txt" 3))
            (setq file1 (open f "w"))
                (setq i 0)
                (while (< i (length ret))
                    (setq row (nth i ret))
                        (setq n (itoa 1))
                        (setq type (car row))
                        (setq di (rtos (cadr row) 2 2))
                        (setq ang (last row))
                        (setq row (strcat n "," type "," di "," ang))
                        (write-line row file1)
                    (setq i ( 1+ i))
            (princ "Done!")
            (close file1)
            (princ)
      (princ)
Miljenko Hatlak
Message 8 of 30
bit_Cad2018
This Code Extremely well
Thanks 🙏 hak_vz. 🙏 may god bless you
Message 9 of 30
@hak_vz,
Your Lisp code is very good. It is also very useful for me. I have tested your lisp on some file and it is showing errors in some files. In the first sample 1 file your lisp is saying some
angle wrong I highlighted in excel and in the second Test2 file, your lisp is not getting any results.
Message 10 of 30
hak_vz
At the moment I don't have a time to test it, will try to do it during the weekend. In your drawings try to use only lwpolylines and layer names should be identical to sample drawing provided above. You have a task to check out on what intersections code produces an error. This code was written without thorough checking, but a guess it may be usefull. As with any code you have to check final result and make changes if necesary.
Miljenko Hatlak
Message 11 of 30
bit_Cad2018
crossing line flow change then try.
Thanks Bhau for reply
Message 12 of 30
@hak_vz,
You have rightly said that I have not noticed the layer of the mainline, but still there is a mistake in finding the angle. Sometimes this angle starts searching from some other direction.
And the second mistake is that it only detects the same angle as can be seen on your screen. If we assume that the mainline is too long and we have to zoom and select it, it will lose too much angle of the line.
When you have much time, please you should update it..
@bit_Cad2018,
This is not a complete solution because if we are trying to find the angle of an adjacent line, it has to find the angle from the same direction, and each time the direction of the line cannot change and we don't even know that the code Which line has chosen which angle from which direction.
Message 13 of 30
hak_vz
Here is a sheme that describe how code works. In reality it only takes one situation (one angle), while actually there are two, and there is a cross similarity .I'll have to update code to calculate both angles. Actually we have to decide to show angles from either left or right side.
Proposal: imagine  that we move along the section line and on crossing, we treat sectionline to have first point on a right side to section line. We have to decide for  one of options.
At the moment code calculates angle between vectors x-1 and x-b.
Miljenko Hatlak
Message 14 of 30
@hak_vz,
Sorry for the late reply, I went on vacation with the family. So I suggest that whoever is crossing the line in increasing order from the mainline, should find the angle from the left as i shown in Sample1 drawing.
Message 15 of 30
hak_vz
Here is updated script. I hope that will now work correctly.
                 cdist pipeline ss_cross npoints ent i pts e a seg ip di v1 v2 e ang type n ret *error* table row *acdoc* tmp f file1)
    (vl-load-com)
    (defun asin (x)
      (cond
        ((= x  1) (/ pi 2))
            *fuzz* 1e-10
        (if (and ent)
            (progn
                (setq i 0)
                    (setq i (+ i 1))
       pset
    (setq cdist 0 i 0)
    ;(setq ss_cross (ssget "x" (list '(0 . "lwpolyline") '(-4 . "<not")'(8 .  "Proposed Pipeline") '(-4 . "not>"))))
            (if ss_cross
                (progn
                               (foreach e int_segs
                                    (if (= (vectorSide start end p1) -1) (setq tmp p1 p1 p2 p2 tmp))
                                    (if ip
                                        (setq
                                            v1 (vector ip start) v2 (vector ip p1)
                                (setq j (+ j 1))
       (progn
                (+ 2 (length ret))
                    5			; cell height
                    30			; row width
          (setq row 2 i 0)
          (foreach item ret
      (progn
                (setq i 0)
                        (setq n (itoa 1))
                    (setq i ( 1+ i))
            (princ "Done!")
            (close file1)
            (princ)
      (princ)
Miljenko Hatlak
Message 16 of 30
@hak_vz,
You fixed the code to find an angle from one direction, but it is looking for the opposite direction. Possibly I made a mistake in telling you, have you checked the angle of the test 1 drawing?
Message 17 of 30
hak_vz
Change in script line
with
(if (= (vectorSide start end p2) -1) (setq tmp p1 p1 p2 p2 tmp))
Test it, and report result
Miljenko Hatlak
Message 18 of 30
@hak_vz,
This is perfect, I salute you. Thanks a lot.👍
Message 19 of 30
hak_vz
If this is it regarding angle direction I will also add line object as possible crossing object. I have updated code so now it can cope with object that are crossing our section object at different sections.
How long are your profiles? If you have this pipeline object divided in sections you obviously have to at stations - starting distance value.
Miljenko Hatlak
Message 20 of 30
It cannot be said with certainty what the length of the pipeline may be, it can be according to different projects. But now we assume that the length of the pipeline is 700 km and the approximate crossing is 300. At such times, your code may fail to find the entire crossing angle, but according to what you suggested, if we split the pipeline and add the initial staring chainage value method, it is also largely correct by Will be done.
You have put a lot of effort into this Lisp code, I am satisfied for now. If you think you can improve this code even more, than I will be grateful to you.
