Criar imagem para comando AutoCAD (Create Image for AutoCAD Command )
Boa tarde Pessoal,
Gostaria de saber como faço pra criar uma imagem para um novo comando criado para o autocad, para que ela fiquei igual aos comando originais do autocad
Good afternoon people,
I would like to know how to create an image for a new command created for autocad, so that it was the same as the original autocad command.
ВeekeeCZ
Well, there is nothing much special about those icons. It's more about your graphics skills... I usually export some actual icon from autocad and make just small adjustments in Window Paint program (with zoom of 400%). But it could be done with Gimp or some other graphics program or some programs specifically focused on icons... you may look for it -- maybe THIS ONE ? Even there is a small icon editor build-in inside of autocad (see the screenshot, "Edit" option above the red arrow)
Small icons are 16x16, large 32x32 px
Use *.bmp, newer versions of autocad supports *.png as well
Use color 192,192,192 which goes to be a transparent in autocad.
If nothing changed in new versions then large icons are unable to export from autocad - some bug or something.
