creation of layouts based on data in model space
Message 1 of 13
hello,
got a bit of a question which may be an absolute pipe dream but here goes....
if i have a drawing with one layout, does anybody know or heard of a way to do the following using a lisp or script?
If i create lets say 4 rectangles which represent 1:500 viewports at A1 in my model, is there a way to duplicate the original layout and center each new viewport within these new layouts based on the rectangles within the model space?
Layout 1 = viewport matches rectangle 1
Layout 2 = viewport matches rectangle 2
Layout 3 = viewport matches rectangle 3
Layout 4 = viewport matches rectangle 4
i know how to set the view ports based on a centroid using a lisp, but not sure if new layouts can be copied/created based on some specific objects within the model space.
Replies (12)
Message 2 of 13
bump
Message 3 of 13
hmsilva
Hi camardi,
quick and dirty,
test the code with the demo.dwg, not testing for UCS, rotated recangles, etc..
Just a starting point...
(defun c:demo (/ a b i lyt nm mx pt ss)
  (setq i 1)
  (while (setq ss (ssget "_+.:E:S" '((0 . "lwpolyline") (-4 . "&=") (70 . 1))))
    (vla-getboundingbox (vlax-ename->vla-object (ssname ss 0)) 'mn 'mx)
    (setq pt (mapcar '(lambda (a b) (/ (+ a b) 2)) (vlax-safearray->list mn) (vlax-safearray->list mx)))
    (setq lyt (strcat "Layout" (itoa (setq i (1+ i)))))
    (command "-layout" "_C" "Layout1" lyt)
    (setvar 'CTAB lyt)
    (command "_.mspace")
    (command "_zoom" "_C" pt "")
    (command "_.pspace")
    (setvar 'CTAB "Model")
  (princ)
Hope this helps,
Henrique
Message 4 of 13
Thanks mate, it is a great start.
all i need to try and work into that now is a bit of "IF" and try and remove the selection process and replace it with "IF" there is a layer x create layout, "IF" layer y create another layout, if there isnt layer z end process.
Thanks again, i'll have to brush up on my autolisp skills again 🙂
Message 5 of 13
hmsilva
You're welcome, camardi.
Glad I could help.
For the 'if' I would suggest just start filtering the layer names
(vl-load-com)
(defun c:demo (/ a b i layt layt_lst mn mx obj pt ss)
  (setq layt_lst (layoutlist))
  (if (setq ss (ssget "_X"
                      (list '(0 . "lwpolyline") '(-4 . "&=") '(70 . 1) '(8 . "x,y,z") (cons 410 (getvar 'CTAB)))
    (repeat (setq i (sslength ss))
      (setq obj  (vlax-ename->vla-object (ssname ss (setq i (1- i))))
            layt (vla-get-layer obj)
      (vla-getboundingbox obj 'mn 'mx)
      (if (not (vl-position layt layt_lst))
        (progn
          (command "-layout" "_C" "Layout1" layt)
          (setvar 'CTAB layt)
          (setq layt_lst (cons layt layt_lst))
  (princ)
Hope this helps,
Henrique
Message 6 of 13
hey mate, what is the best way to do the filter using the autolisp language?
i havent really had too much of a play with some of this and normally try to just cheat and use a script most times.
Message 7 of 13
hmsilva
Hi camardi,
you'll have to be more specific relative to what you need to filter...
Henrique
Message 8 of 13
basically i will draw a rectangle on an individual layer for layout tab required.
i will also have to use something to say if there isnt a layer, stop the cycle and continue the lisp. thats why i was thinking the "IF" function before...
example
ie
Project 1
layer            layout
if
window 1 = layout 1
if
window 2 = layout 2
if
window 3 = layout 3
if
window 4 = layout 4
**continue
Project 2
layer            layout
window 1 = layout 1
if
window 2 = layout 2
if
window 3 = layout 3
if
window 4 = layout 4
if
window 5 = layout 5
if
window 6 = layout 6
**continue
Message 9 of 13
hmsilva
Hi camardi,
to easier reading I did add some comments to the following code.
If you do not understand something, just ask...
(vl-load-com)
(defun c:demo (/ a b i lay layt layt_lst mn mx num obj pt ss)
  ; creates a list with the names of existing layouts
  ; creates a selection set with closed lwpolylines, in current tab,
  ; and filter layers names with 'window' a 'space' and a numeric character.
  ; test if a valid selection set exists, and if true
                      (list '(0 . "lwpolyline") '(-4 . "&=") '(70 . 1) '(8 . "window #*") (cons 410 (getvar 'CTAB)))
  ; repeat the selecton set length
      ; set as a vla object
            ; get the name property
            lay  (vla-get-layer obj)
            ; get the numerical part from the layer name
            num  (substr lay (+ (vl-string-position (ascii " ") lay) 2))
            ; set the new layout name, 'layout' 'space' and numerical part
            layt (strcat "layout " num)
      ; test if layout name don't exists in layout list,
      ; and if true
        (progn
          ; get the lwpolyline bounding box
          ; calculate the center point from bbox
          ; copy 'Layout1' and set the new layout with the previous name stored in layt variable
          ; set the new layout, as current
          (setvar 'CTAB layt)
          ; activate floating model space
          ; zoom to the lwpolyline center point
          ; return to paper space
          ; return to model space
          ; store the new layout name in layout list
  (princ)
Hope this helps,
Henrique
Message 10 of 13
Thanks a lot, with a little bit of tweaking (just changing layer names etc) with it, It works absolutely perfectly for what i want.
Message 11 of 13
hmsilva
You're welcome, camardi!
Glad I could help
Henrique
Message 12 of 13
hey its me again 🙂
still loving the lisp, got a fe further questions
- do you think the polyline/layer could be part of a xref (nested object)? i tried to modify it along the lines of "*window *" by putting a wildcard infront, but failed, but most likely because it couldnt find a polyline, instead a block. No biggy if it cant, i wrote a script to bring in a xref, bind it and explode it to every drawing which works great as well.
- could i set the viewport scale based on the dimensions of the polyline, which i think would also raise the question of the rotation based on the polyline...i was think of adding a line before
(command "_zoom" "1000/500xp")
which would set the scale first before centering it. which i suppose i could look into a mv rotation as well based on a object.
- automatic sorting of the new layouts would be awesome as well 🙂
I'm away from my CAD computer all weekend, so will be having a crack at this before work on monday.
i thoughly recommend this lisp to anyone by the way. .
Message 13 of 13
hmsilva
Hi camardi,
I think it would be possible to use the polylines in the xref, but currently I have a few deadlines to meet, so I don't have much free time.
As soon as I have some spare time, I'll see what I can do...
Henrique
