Creating spline from 3d space on plane XY as projection
malmal02122023
malmal02122023
I need to create a spline on plane XY from polyline (el. 5600, green color), where axis X stay the same coordinate and axis Y is the length of polylines (frames) see attachment below. In attachment dwg and txt files included. txt describe command for creating extension line with maintaining polyline length and transfer ones on plane XY.
Procedure:
1. select frames and elevation polylines
2. frames polylines should be trim above  el.5600
3. then from selected polylines extension polylines are created on plane XY
4. create spline on ends of new extented lines.
Is it possible create one command for this procedure?
Thanks for the advice.
diagodose2009
I got your programe.txt, I re-write some sourcesLines, but  I failed.
Why (command "pline") do not work?
Can I replace the (command "pline" with my function "dfn_enamk_lwpoly"?
