. Creating Directories / Folders
Message 1 of 13
Which is the easiest or neatest way to create new folders or directories -
Using LISP or VLISP - AutoCAD 14 & 2000
(Preferably - without using "SH")
V Abela
Replies (12)
Message 2 of 13
You can use VL-MKDIR: (vl-mkdir "c:\\test")
Returns T if sucessful, nil otherwise
Get free software and more at http://www2.stonemedia.com/franko
"AES" wrote in message
news:89mr3t$him19@adesknews2.autodesk.com...
> Thanks
> V Abela
Message 3 of 13
Download DOSLib from www.mcneel.com. Unlike the (VL-MKDIR), DOSLib's
(DOS_MKDIR) function works in both R14 (LISP and A2K (VLISP). And hey, it's
free.
Dale Fugier
Robert McNeel & Associates
www.mcneel.com
"Frank Oquendo" wrote in message
news:89mrtv$hh725@adesknews2.autodesk.com...
directories -
> > Thanks
> > V Abela
Message 4 of 13
I need to use it for AutoCAD 14 as well
Frank Oquendo wrote in message
directories -
> > Thanks
> > V Abela
Message 5 of 13
Thanks, but
Must work with AutoCAD 14 - As well
V Abela
directories -
> > Thanks
> > V Abela
Message 6 of 13
Must be in LISP or VLISP - cannot use 3rd party
V Abela
Dale Fugier wrote in message
news:89msed$hhj16@adesknews2.autodesk.com...
it's
> free.
> Dale Fugier
> www.mcneel.com
> directories -
> > > Thanks
> > > V Abela
Message 7 of 13
Okay....
(command "._SH" (strcat "MKDIR " dirname))
You can also use a different PGP command that will not
display the DOS window.
> Thanks
> V Abela
> it's
> > free.
> > Dale Fugier
> > www.mcneel.com
> > directories -
> > > > Thanks
> > > > V Abela
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 8 of 13
Thanks Tony
But would realy prefer not to use the "Shell" command
Victor
Tony Tanzillo wrote in message
news:38BF0114.EEA04C73@worldnet.att.net...
> Okay....
> > Thanks
> > V Abela
hey,
> > it's
> > > free.
> > > Dale Fugier
> > > www.mcneel.com
> > > directories -
> > > > > Thanks
> > > > > V Abela
Message 9 of 13
In that case, you are fresh out of luck.
You have gotten several responses from others here
showing how to do it using various external solutions,
but unfortunately, using nothing but R14 WITHOUT any
ARX or ActiveX extension, means that you have no
choice but SHELL.
AES wrote:
> Thanks Tony
> Victor
> > Okay....
> > > Thanks
> > > V Abela
> hey,
> > > it's
> > > > free.
> > > > Dale Fugier
> > > > www.mcneel.com
> > > > directories -
> > > > > > Thanks
> > > > > > V Abela
Message 10 of 13
Before I discovered McNeel, I accomplished this by writing a simple VBA
program to create the new folder, and accessed it with AutoLISP using the
vbarun command. Before running the vbarun command, I used the open and
write-line functions to make a temporary file with the name of the new
directory, which was read by the VBA program. So it was totally under the
control of the LISP program, even though part of it was VBA.
If the solution you have to use for R14 isn't desirable for A2K, I would use
an "if" function to determine which version you are in, and act accordingly.
AES wrote in message <89mr3t$him19@adesknews2.autodesk.com>...
Message 11 of 13
Out of interest, why can't you use 3rd parties?
Doslib was supplied on the cd so it could be thought of as only 'semi' 3rd
party if it's security your worried about.
Regards
Dave Fox
news:89mthi$hif19@adesknews2.autodesk.com...
> Thanks
> V Abela
> it's
> > free.
> > Dale Fugier
> > www.mcneel.com
> > directories -
> > > > Thanks
> > > > V Abela
Message 12 of 13
I think it's because he is a third party himself and doesn't want reliance
on somebody else.
Joshua Tapp ( josht@scm-ae.com )
Designer/Intern - Architecture Group - SCM Consultants, Inc. -
http://www.scm-ae.com - A part of Infrastructure Northwest Group -
http://www.ttinw.com - Division of Tetra Tech, Inc. - http://tetratech.com
david fox wrote in message
news:8a1fup$mbq17@adesknews2.autodesk.com...
Message 13 of 13
I've never understood the aversion to proven, tested third-party components.
Why reinvent the wheel? Worse yet, what if you're given the source and it
proves to be beyond your current skill set to maintain?
Visit me at: http://www2.stonemedia.com/franko
"Joshua Tapp" wrote in message
news:8a1gbk$mc121@adesknews2.autodesk.com...
> on somebody else.
