Creating a Script for Changing LTS to 1 in all drawings
jcruickshanks
jcruickshanks
Hi all,
I'm quite new to using scripts and trying to create one to change LTS to 1 in a large batch of drawings where the LTS seems to vary (drawings were created by several people over many years). I tried to write a simple script but it doesn't seem to be working:
ltscale
1
qsave
It seems as if it gets stuck after typing 1, can someone please advise what I'm doing wrong
Kent1Cooper
Define "it gets stuck."  What happens?  What does the Command line show?  Is there any error message?  Etc., etc.
Kent Cooper, AIA
Nathan_Tigner
If it is an actual script (.scr), make sure you have a blank space at the end of the script that cad recognizes as ENTER. Maybe this is why it's getting stuck after 1.
ronjonp
Maybe this?
(setvar 'ltscale 1)
"_.qsave _.close"
Or use THIS tool and use this as the input _.open *file* (setvar 'ltscale 1) _.close
calderg1000
Regards @jcruickshanks
Try the following code
(defun c:tsc ( / s i e)
  (setq s (ssget "_X"))
  (repeat (setq i (sslength s))
    (setq e (ssname s (setq i (1- i))))
    (setq en (vlax-ename->vla-object e))
    (vla-put-linetypeScale en 1)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
jcruickshanks
Thanks, the first script didn't seem to work again but I used the tool you suggested and the second script worked perfectly (I added _.qsave before close).
ronjonp
Good catch on the _.qsave ... it's been a minute since I've ran scripts 🙂
