Creating a lisp that generates 1 polyline per linetype in a DWT : Rotation of text help !
cyberflow
Advisor Advisor
Message 1 of 9
cyberflow
Hi all,
I'm trying to make this work and be more automated and it generates 1 linetype per polyline and it asks only to select a first polyline and it offsets it and add text to the right so we can see what is the linetype name
But the thing is that the text doesnt rotate properly
I'm wondering what i'm missing ?
P.S. I tried with Grok AI tool to give me help so i can get this ready quickly but without a solution
The code :
(defun C:OffsetPolyWithLinetypes (/ *error* ss dist layer linetypes lt-index i pline offset-ent vla-obj doc num-offsets endpt text-pos text-obj)
  (vl-load-com)
  ;; Error handler
  (defun *error* (msg)
    (if (not (member msg '("Function cancelled" "quit / exit abort")))
        (princ (strcat "\nError: " msg))
    (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
    (setvar "CMDECHO" 1)
    (princ)
  ;; Start undo mark
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  ;; Set system variables
  (setvar "CMDECHO" 0)
  (setq layer (getvar "CLAYER")) ; Current layer
  ;; Get all available linetypes in the drawing
  (setq linetypes '())
  (tblobjname "LTYPE" "*") ; Initialize table scan
  (while (setq lt (tblnext "LTYPE" (null lt)))
    (setq linetypes (append linetypes (list (cdr (assoc 2 lt)))))
  ;; Load additional linetypes from acad.lin if fewer than 2 linetypes
  (if (< (length linetypes) 2)
      (progn
        (command "._LINETYPE" "_Load" "*" "acad.lin" "")
        (tblobjname "LTYPE" "*") ; Reset table scan
  ;; Remove "CONTINUOUS" linetype to avoid assigning it
  (setq linetypes (vl-remove "CONTINUOUS" linetypes))
  ;; Sort linetypes alphabetically
  (setq linetypes (vl-sort linetypes '<))
  ;; Check if linetypes are available
  (if (null linetypes)
      (progn
        (princ "\nNo linetypes available to assign.")
        (*error* "No linetypes")
  ;; Set number of offsets to the number of available linetypes
  (setq num-offsets (length linetypes))
  (princ (strcat "\nCreating " (itoa num-offsets) " offset polylines based on available linetypes."))
  ;; Prompt for polyline selection
  (princ "\nSelect polylines to offset: ")
  (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE"))))
  (if (not ss)
      (progn
        (princ "\nNo polylines selected.")
        (*error* "No selection")
  ;; Prompt for offset distance
  (initget 1)
  (setq dist (getdist "\nSpecify offset distance (positive for one direction, negative for opposite): "))
  (if (not dist)
      (progn
        (princ "\nInvalid offset distance.")
        (*error* "No distance")
  ;; Process each polyline
  (setq lt-index 0 i 0)
  (while (< i (sslength ss))
    (setq pline (ssname ss i))
    (setq vla-obj (vlax-ename->vla-object pline))
    ;; Create offsets for each available linetype
    (repeat num-offsets
      (setq offset-dist (* dist (1+ lt-index))) ; Incremental distance
      (if (setq offset-ent (vlax-invoke vla-obj 'Offset offset-dist))
          (progn
            ;; Set the offset polyline to the current layer
            (vla-put-layer (car offset-ent) layer)
            ;; Assign a linetype from the sorted list
            (setq ltype (nth lt-index linetypes))
            (vla-put-linetype (car offset-ent) ltype)
            ;; Calculate end point of the offset polyline for text placement
            (setq endpt (vlax-curve-getendpoint (car offset-ent)))
            ;; Offset text to the right (same distance as offset)
            (setq text-pos (polar endpt (if (> dist 0) 0.0 pi) (abs dist)))
            ;; Create text with linetype name using ActiveX
            (setq text-obj (vla-addtext
                             (vla-get-modelspace doc)
                             ltype
                             (vlax-3d-point text-pos)
                             (* (abs dist) 0.3)))
            (vla-put-alignment text-obj acAlignmentMiddleLeft)
            (vla-put-textalignmentpoint text-obj (vlax-3d-point text-pos))
            (vla-put-rotation text-obj (/ pi 2)) ; 90 degrees in radians
            (vla-put-layer text-obj layer) ; Set text to current layer
            ;; Verify rotation
            (if (/= (vla-get-rotation text-obj) (/ pi 2))
                (progn
                  (vla-put-rotation text-obj (/ pi 2)) ; Reapply rotation
                  (princ (strcat "\nReapplied rotation for text: " ltype))
            (setq lt-index (1+ lt-index)) ; Increment linetype index
    (setq i (1+ i))
  ;; Clean up
  (vla-endundomark doc)
  (princ (strcat "\n" (itoa (* i num-offsets)) " offset polylines created with linetype labels."))
  (princ)
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Accepted solutions (3)
Replies (8)
Message 2 of 9
Sea-Haven
I don't quite understand why your making repeated objects with linetypes of multiple plines. Are you trying to make a legend of the used Linetypes and also in my case used blocks ? I have something for that.
Message 3 of 9
cyberflow
@Sea-Haven : Im doing some cad and template management right now and sorting linetypes
Im curious, what do you have ?
Frank Freitas
LinkedIn
Message 4 of 9
5w1tch2
Observer
Observer
(defun c:OPWL (/ *error* ss dist layer linetypes lt-index i
                 offset-dist endpt tanVec text-angle text-pos text-obj)
  (vl-load-com)
  ;; ERROR HANDLER
    (princ)
  ;; START UNDO MARK / SETUP
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (vla-startundomark doc)
  ;; GET AVAILABLE LINETYPES
    (setq linetypes (cons (cdr (assoc 2 lt)) linetypes))
  ;; LOAD FROM acad.lin / NOT ENOUGH LINETYPES
    (progn
  ;; FILTER
  ;; VALIDATE LT
    (progn
      (princ "\nNo linetypes available.")
      (*error* "No linetypes found")
  ;; PROMPT FOR PL
  (princ (strcat "\nCreating " (itoa (length linetypes)) " offset polylines with linetypes..."))
  (if (not ss)
    (progn
  ;; PROMPT FOR OFFSET DISTANCE
  (initget 1)
  (setq dist (getdist "\nSpecify base offset distance: "))
  (if (not dist)
    (progn
      (princ "\nInvalid distance.")
      (*error* "No distance specified")
  ;; MAIN LOOP THROUGH PL
        lt-index     0
        i            0)
    ;; REPEAT
    (repeat num-offsets
        (progn
          ;; Set linetype and layer
          (vla-put-Layer     (car offset-ent) layer)
          (vla-put-Linetype  (car offset-ent) ltype)
          ;; Get direction and position for text
                tanVec     (vlax-curve-getfirstderiv (car offset-ent)
                                                    (vlax-curve-getendparam (car offset-ent)))
                text-angle (atan (cadr tanVec) (car tanVec))
                text-pos   (polar endpt text-angle (* 1.5 dist)))
          ;; ADD ROTATED LABEL
          (setq text-obj
            (vla-addtext
              ltype
          (vla-put-Rotation text-obj text-angle)
          (vla-put-Layer    text-obj layer)
    (setq i (1+ i))
  ;; WRAP IT UP
  (princ (strcat "\nDone. " (itoa (* i num-offsets)) " offset polylines created."))
  (princ)
Message 5 of 9
cyberflow
Thanx for that idea @5w1tch2
I've adjusted my original lisp with your approach
Frank Freitas
LinkedIn
Message 6 of 9
cyberflow
(defun C:OffsetPolyWithLinetypes (/ *error* ss dist layer linetypes lt-index i pline offset-ent vla-obj doc num-offsets endpt tanVec text-angle text-pos text-obj)
  (vl-load-com)
  ;; Error handler
    (princ)
  ;; Start undo mark
      (progn
  ;; Remove "CONTINUOUS" linetype and sort alphabetically
      (progn
  (if (not ss)
      (progn
  (initget 1)
  (if (not dist)
      (progn
    (repeat num-offsets
          (progn
            ;; Calculate end point and tangent vector for text placement
            (setq tanVec (vlax-curve-getfirstderiv (car offset-ent)
                                                   (vlax-curve-getendparam (car offset-ent))))
            (setq text-angle (atan (cadr tanVec) (car tanVec)))
            ;; Offset text along tangent direction (same as polyline offset)
            (setq text-pos (polar endpt (if (> dist 0) text-angle (+ text-angle pi)) (abs dist)))
                             ltype
            (vla-put-rotation text-obj text-angle) ; Align with polyline
    (setq i (1+ i))
  ;; Clean up
  (princ)
Frank Freitas
LinkedIn
Message 7 of 9
5w1tch2
Observer
Observer
Glad it helped @cyberflow
Message 8 of 9
Sea-Haven
@cyberflow give this a try, it looks at the model for objects.
Message 9 of 9
cyberflow
Hey @Sea-Haven thanx !
Frank Freitas
LinkedIn
